Finite-Temperature Schrödinger's equation
Gavroy
hi,
i am interested in solutions to the finite-temperature schrödinger's equation for the hydrogen atom. does anybody know whether there are such?
or does anybody of you know whether there is a possiblity to use something like pertubation theory to calculate the new energy-levels of the hydrogen atom at some temperature?
What "new" energy levels? The states themselves don't change with temperature.
are you sure? then why do they invent this new formula.
http://arxiv.org/PS_cache/arxiv/pdf/1005/1005.2751v3.pdf" (23).
does a new term in the hamiltonian not result in new energy levels?
or let me ask it in a different way: what exactly happens when a hydrogen atom is at temperature T and how can i describe this state(or this fluctuation, whatever it is) mathematically?
Yes I'm sure. That doesn't show otherwise either. A more important question to Why did they invent it:
Where/when has anyone used it? I do actual finite temperature calculations on atoms and molecules all the time, and I certainly haven't either seen it or needed it.
That's not the Hamiltonian of a single atom or a single particle. You're comparing apples to oranges.
Create a partition function. Don't you know statistical thermodynamics at all?
no, up to now, i was only concerned with mechanics, classical field theory and qm...
actually, it is completely new to me to use statistical mechanics in hydrogen atoms, that have discrete energy levels. how does statistical mechanics work with quantum mechanics?
if it is not too demending, it would be great if you could write down the correct function that gives me the probability for hydrogen atoms at a finite temperature or you could give me a link, where they deal with this problem.
thanks for your help
We often see discussions about what QM and QFT mean, but hardly anything on just how fundamental they are to much of physics. To rectify that, see the following; https://www.cambridge.org/engage/api-gateway/coe/assets/orp/resource/item/66a6a6005101a2ffa86cdd48/original/a-derivation-of-maxwell-s-equations-from-first-principles.pdf 'Somewhat magically, if one then applies local gauge invariance to the Dirac Lagrangian, a field appears, and from this field it is possible to derive Maxwell’s...
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
