Fletcher's Cart Lab: What is it?
  • Thread starter Thread starter NIZBIT
    Cart
Fletcher's cart appears to be a less common name for a lab experiment, possibly referring to Fletcher's Trolley. The original poster is struggling to find information on Fletcher's cart despite knowing where to purchase the necessary equipment. There is a request for clarification on whether the lab is known by a different name. Participants are encouraged to share any resources or insights on locating information about the lab. The discussion highlights the confusion surrounding the terminology used for this specific lab experiment.
NIZBIT
Fletcher's cart?
I am doing a lab on Fletcher's cart. When I try to do a search on this nothing comes up. Is this lab go by another more popular name?
Are you thinking of Fletcher's Trolley?
I think that is what they meant. Thank you!
Ugh! I am having no luck finding any info on this lab. Although I know exactly where to buy the equipment, it doesn't help. Does anyone know where I could find this?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
