Flow in a pipe with a tank on its top, and a nozzle on its bottom
To achieve 1000 rpm from a Pelton turbine using a tank of water, the height of water (h) in the tank and the nozzle diameter are critical factors. The nozzle must be sized to minimize flow restriction while maximizing water speed, which is influenced by the turbine specifications and the tank height. Maintaining the outlet diameter of the pipe can help reduce flow restriction. The feasibility of reaching 1000 rpm depends on the specific turbine design and the water height. Proper calculations and specifications are necessary to determine the optimal nozzle diameter and tank height.
ecm00
I have a tank filled with water on the top of a pipe (height of water = h)
there's a hole in the bottom of the tank, so that when the hole is suddenly opened, water will flow in the pipe of length 20 meters
at the bottom of the pipe, there's a nozzle (I don't know how to choose the right nozzle diameter in order not to restrict water flow, and to increase water speed)
the jet from the nozzle will hit a pelton turbine of 20 cm diameter
I want to get about 1000 rpm from the turbine. How can I choose the height of water in the tank and the nozzle diameter? Is 1000 rpm achievable?
any sort of nozzle is going to restrict the flow, can't be any other way that I can see. The least restriction is when the outlet diameter of the pipe is unchanged
Dave
thx!
so how should I choose the diameter of my nozzle? how to reach 1000 rpm?
ecm00 said:
thx!
Thats beyond my knowledge, I don't know if it can be done or not.
D
That depends on the spec of your turbine, whatever it's attached to, and the "h" of your tank.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
