Fluid - Determining pump power for pipe flow system
To determine pump power for a pipeline with a constant head and a 20% increase in flow rate, apply the steady flow energy equation, incorporating losses from pumps, minor losses, and head losses. Calculate the head loss using the given friction factors for the pipes and the Z value of 9.997m of water. Neglect certain variables due to both points A and B being exposed to ambient air. Solve for the hydraulic head (h(p)) and substitute this into the pumping power equation to find the required power (P). Additional assistance can be provided if needed after attempting the calculations.
Nismo7
Fluid - Determining pump power for pipeline with constant head
gentlemen, i need some help to solve for part b as attached. The friction factor for pipe 1 & 2are 0.003106 and 0.003438 respectively and the Z value calculated is 9.997m of water. With a 20% increase in flow rate for the piping system, what is the approach i should take to solve this question?
Thank you
Use the steady flow energy equation. The complete equation should include losses due to pumps, minor losses, and head losses.For all similar problems, write out the equation, and begin to rule out variables.
Hint: It seems that both point A and B are both exposed to ambient air...this allows you to neglect some things.
Solve for h(p). Then plug this into the pumping power equation, and solve for P.
If you still need help, or need the specific equations after trying it out yourself, let me know.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
