Fluid Mechanics Newtons law of viscosity
wozzers
having problems differentiating
Tw ( wall shear stress)= -U(viscosity)*du/dr
been given u as 2V(1-(r/r)^2)
i substituted u in and got
d/dr (2V(1-(r/r)^2)
i tried to multiply out the minus sign and 2V and got a very different answer i got -2V+2V (r/r)^2
when the answer is supposed to be -4VR/R^2
please help
What do you mean here:
been given u as
2V(1-(r/r)^2) = 2V(1 - 1) = 0
Do you mean
<br /> u = 2V\left(1 - \left(\frac{r}{r_0}\right)^2\right)<br />
where r_0 is the radius of what I assume to be a cylindrical pipe?
d/dr (2V(1-(r/r)^2)
please help
The given answer is for du/dr; to get T_w you have to multiply that by -\mu.
So far all you've done is multiply u by -1. Try differentiating with respect to r first.
r=R and its (r/R)^2
okay now i have differentiated it with respect to r i get 2V2r/R^2) or -(4Vr/R^2) thanks again i was then required to use the wall shear stress to determine the frictional force but it is very straight forward from there
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
