Fluid mechanics problem involving a hose and water coming out.
The discussion centers on solving a fluid mechanics problem involving water flow through a hose. Participants emphasize the importance of applying conservation of mass, specifically noting that the volumetric flow rate must be equated at two different cross-sections. The initial approach of using V1*A1=V2*A2 is critiqued, leading to a clarification that the average velocity should be calculated using an integral approach to account for varying flow across the radius. Additionally, Bernoulli's principle is suggested to determine the uniform velocity at the exit, allowing for the calculation of diameter ratios. Overall, the conversation focuses on integrating fluid dynamics principles to accurately analyze the flow problem.
guitar24
I am having some trouble starting this problem. At first look I would say that a conservation of mass will give V1*A1=V2*A2 for steady state incompressible fluid. Then I would solve for A2 and relate the two diameters but I don't have the velocity distribution of the water stream. Any hints??
You're spot on to include conservation of volume, but V1*A1 = V2*A2 can't be right since the flow of water thru A1 varies with r. So think of the total volume of water flowing in 1 sec. thru A1 and equate that to the total volume of water flowing in 1 sec. thru A2.
Thank you for your reply! could you elaborate a bit more on how I would do that?
The total volumetric flow rate in the tube is Vavg*Area of the tube. Multiply by one and you get the volume of water entering the cross section in one second. Then i would just divide that by the area of the water stream to get the volume of water flowing in one sec through the area of the water stream. Then just rearrange the equation to get Dout/Dhose. Is that correct?
Thank you!
Thank you!
I computed the average flow per unit time and found it to be not Vavg but (1/R)∫v(r)dr with limits 0 and R, = (4/3)Vavg which is somewhat weird.
Anyway, whatever average V is, you are right in using mass conservation flow to get the answer. But you still need to get v, the (uniform) velocity of the stream exiting at Dout. For that, go to Bernoulli.
Given the assumption that there is no interaction with the surrounding air and thus no momentum loss, that suggests momentum is constant. Write integrals representing the momentum at the nozzle using the given velocity profile and one for the region downstream (utilizing conservation of mass flow) where the velocity is uniform. Equate them and solve for diameter ratios.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
