FLUID MECHANICS QUESTION: Froude's Number
To determine the actual flow for the prototype spillway based on the model scale of 1:20, the flow rate for the model is given as 100 L/s per meter, translating to 0.1 m³/s per meter. The length scale ratio is established as 20, indicating that the prototype is 20 times larger than the model. The relationship between the flow rates is defined by the equation qr = qp/qm, where qr is the prototype flow rate, qp is the model flow rate, and qm is the model flow rate per meter. The user is seeking to calculate the velocity (Vr) to find the prototype flow rate (qp) using the established relationships. The solution hinges on determining Vr to complete the calculation for the prototype spillway's flow.
KAISER91
A model spillway has a flow of 100 L/s per m of width. What is the actual flow for the
prototype spillway if the model scale is 1:20?
qr = qp/qm
My attempt;
qm = 100 L/s per m = 0.1 m^3/s per m
Using the length scale ratio: Lr = Lp/Lm = 20/1 = 20
q = Q/b = VA/b = byV/b = yV
therefore, q = yV
hence, qr = yr Vr
yr = Lr which is 20
So how do I get Vr?
Once I know Vr, I will get qr
Then I can resolve the flow for the prototype using this;
qr = qp/qm
qp = qr x qm
with qm given as 0.1
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
