Fluid question: Detecting Blood Pressure in Mice
Detecting blood pressure in mice can yield lower readings than expected due to potential issues with the setup. The diameter of the pipe and the sharpness of its tip may influence pressure readings, but other factors must also be considered. Calibration of the blood pressure detector and control conditions are crucial for accurate measurements. Viscous losses in the system could contribute to lower readings. Further investigation into these variables is necessary to diagnose the problem effectively.
magic_castle32
Need some help regarding fluid flow and pressure detection:To detect blood pressure in a mouse, we usually insert a small pipe with a refined tip into the artery that is connected to a blood pressure detector. However, the problem we have been getting is that the detected blood pressure is lower than it actually should be.
Why is this the case?
Would changing the pipe diameter, or 'pointiness' of the tip, be of help in getting a more accurate reading?
Without more information, it's hard to diagnose the problem:
How is the detector calibrated? What is your control condition? How do you know the readings are incorrect?
For example, do you also take a reading in the tail vein?
The experimental setup is properly calibrated.
I just want to know if the pipe diameter, or the 'pointiness' of the tip of the pipe, could influence the pressure. Otherwise we'd have to look into other variables, or other aspects of the set-up.
It's easy to imagine viscous losses which would give low pressure readings. But again, without any information about your setup, it's hard to say anything definitive.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
