I Fluid Viscosity & Viscous Friction Between Plates
When a fluid is placed between two parallel plates, with one plate moving and the other stationary, viscous friction arises due to the fluid's viscosity, described by the equation F = -ηA(dv/dy). The viscosity reflects the intermolecular forces within the fluid, while the no-slip boundary condition at the plates ensures that there is no relative motion at that interface. The discussion emphasizes that all shear occurs between fluid molecules, not between the fluid and the plates, making viscous friction dependent solely on the fluid's viscosity. The terminology around this phenomenon can be misleading, as it is more accurately described through shear stresses rather than traditional friction concepts. Understanding these dynamics is crucial for clarity in fluid mechanics.
Dario56
When fluid is placed between two parallel plates such that one plate is moving and other is stationary, fluid will start flowing. Between plate and the fluid there is viscous friction given by equation: $$ F = -\eta A \frac {dv} {dy} $$
where $ \eta $ is fluid viscosity, $A$ is area of a plate and $\frac {dv} {dy} $ is a velocity gradient
Since fluid viscosity is a measure of intermolecular or cohesive forces in a fluid how can its value determine viscous friction between fluid and the plate since interactions between fluid and the plate aren't the same like between fluid molecules?
At the plates, the boundary condition is no-slip (perfect adhesion). That is all that is required.
Likes Lord Jestocost, Dario56 and vanhees71
Dario56 said:
Yes, there is no relative motion between fluid and the plate at that point. However, this doesn't really answer my question.
All the shear is between fluid and fluid. There is no shear movement between metal and fluid.
For that reason the viscous friction is a function of fluid viscosity only.
If we misunderstand your question, then you may need to ask your question again in a different way.
Likes vanhees71 and Dario56
Everything is understood. No slip condition explains my question.
This is why I don't like when textbooks call this phenomenon "friction." It is, I suppose, related to static friction, but that makes it confusing to some because everything is moving so students tend to get a bit wishy washy. I prefer describing it through shear stresses.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
