Flywheel Angular Velocity Problem
A flywheel's rotational kinetic energy is crucial for energy storage, especially as a potential alternative to batteries in electric vehicles. The problem involves calculating the necessary angular velocity for a 13kg flywheel with a radius of 0.3m to store 1.2x10^9 J of energy. The initial calculations yielded an incorrect angular velocity due to a misunderstanding of the moment of inertia formula. It was noted that the correct moment of inertia for a disk involves a factor of 1/2, leading to a significant error in the final answer. The discussion emphasizes the importance of accurate formulas in physics problems.
cchase88
A flywheel is a solid disk that rotates about an axis that is perpendicular to the disk at its center. Rotating flywheels provide a means of storing energy in the form of rotational kinetic energy and are being considered as a possible alternative to batteries in electric cars. The gasoline burned in a 300 mile trip in a typical mid-sized car produces about 1.2x10^9 J of energy. How fast would a 13kg flywheel with a radius of 0.3m have to rotate to store this much energy? Give your answer in rev/min
Rotational Kinetic Energy (KEr) = (1/2)Iw^2
where I = mr^2
So doing some basic algebra, and solving for w, I came up with:
w = sqrt(KEr/.5mr^2)
w = sqrt(1.2x10^9J / .5(13kg)(.3m^2)
w = 45291 rad/s
(45291 rad/s) / 2pi = 7208 rev/s * 60s = 432497 rev/min
The answer that the book is providing is: 6.1x10^5 rev/min
I'm not sure what I'm doing wrong, or If this is even the correct approach I should be taking to solve this problem.
Any help would be greatly appreciated.
Welcome to PF cchase88,
cchase88 said:
where I = mr^2
Are you sure that's the moment of inertia of a disk about an axis passing through it's centre?
Welcome to PF!
Hi cchase88! Welcome to PF! :smile:
Have you noticed you're out by a factor of √2? :rolleyes:
When in doubt, wkikpedia is often helpful: see http://en.wikipedia.org/wiki/Flywheel#Physics :smile:
Thank you both for your help. I forgot about that 1/2. I guess that's what I get for doing a problem at 4 in the morning :rolleyes:
:zzz: cchase 88 z's ! :zzz:​
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
