Forbidden Transitions in the He-Ne Laser?
  • A
  • Thread starter kq6up
  • Tags
    Laser
In summary, The conversation discusses the selection rule for quantum number l in electric dipole approximation, and how transitions differing in l by 1 are allowed. However, diagrams showing energy transitions labeled as "laser" transitions (considered "forbidden") are going from 3s to 3p and 2s to 2p, which should be fast transitions according to selection rules. The experts explain that the favored states for upper laser levels are those with longer lifetimes, and the diagrams may be showing transitions that are not dipole transitions. The conversation also discusses the pumping of the inversion in the He-Ne laser, and how the middle level to ground depopulates faster than the highest level to the middle level, making a
kq6up
368
This is a quick question. This entry in the Laser Encyclopedia states that transitions differing in the angular momentum quantum number "l" by 1 are allowed. Here is the link:
https://www.rp-photonics.com/forbidden_transitions.html
However, diagrams that show energy transitions labeled "laser" transitions (my understanding this are "forbidden") are going from 3s to 3p and 2s to 2p. These should be fast transitions based on what I know about selection rules. What am I missing here? Here is the link to one of the images:
https://upload.wikimedia.org/wikipedia/commons/6/6f/He-ne-laser.svg
Thanks,
KQ6UP
The selection rule for the quantum number ##l## in electric dipole approximation is ##\Delta l = \pm 1##.
So then the 3s, 3p and 2s, 2p should be fast transitions not metastable transitions, correct?
KQ6UP
KQ6UP
They are more precisely the stimulated transition. If the lifetime between those states are too short (which what you possibly mean by "fast transition"), then the pumping rate might not be high enough to keep the population inversion. In fact, the favored states to be used as the upper laser level are those having long lifetime to give more times for the electrons to accumulate in that state before undergoing de-excitation giving up the laser photons.
True, then the states that carry the excited atoms in an inversion should have only slow (not selected) transitions. However, S->P as the diagram shows match the ##\Delta l## condition. This seems like a contradiction, so either I am missing something (more likely), or the diagram I posted the link to is wrong.
Thanks,
KQ6UP
Allowed transition does not always mean fast lifetime, the lifetime of a particular state depends on various things including the energy differences with the nearby states. The term "allowed" here means dipole allowed transition, in which one photon dominates during the transition.
So sometimes the "allowed" state is also the state from which you are stimulating the transition, correct? I was thinking it was always a "disallowed" state to keep the half life of that state long enough to cause an inversion. My understanding is that it could leak out by the lower probability quadrapole term. This is the very thing that is confusing me. However, if a dipole transition is slow enough I guess that can work too. I guess the non-radiative transfer from the Helium is the important part of the pumping of the inversion in this case correct?
Thanks,
KQ6UP
Indeed there is always a leakage through higher order dipole terms but as you have known, their probability is very small and very little photons are emitted via these paths.
In He-Ne laser, the essential transition is the excitation by electron collision (Anregung durch Elektronenstoesse in that picture) in the He atoms. This transition is difficult to realize through optical method because the dipole transition between ground states and 21S and 23S are forbidden. Therefore, an electron staying in levels 21S and 23S will stay for a longer time without too much depletion due to de-excitation back to the ground levels via higher pole terms, and hence will have higher probability to collide with Ne atoms.
Likes kq6up
Got it. So the metastable state here is the species that gets pumped, not the Neon, correct? That makes more sense now. Is there a single species laser that is an example of a four state system. I am trying to choose a clear example for my Laser/Maser paper. Clear cut examples are better, but maybe this is the most well understood system. My paper is longish already, so I wanted the simplest 4 level example to explain.
Thanks,
KQ6UP
Yes, the metastable levels are those two excited levels of He atoms.
If you shift to another point of view, you can actually model He-Ne laser as a 4-level system, for example .
Other examples, according to my literature, includes excimer laser and Nd:YAG laser.
Likes kq6up
Ok, so I think I have this correct now after watching the video. The He is metastable because off forbidden transitions, and the Ne is not metastable because of forbidden transitions, just that it achieves an inversion in homeostasis (if that word is applicable here) because the middle level to ground depopulates faster than the highest level to the middle level. Therefore, a a photon with ##\nu=(E_h-E_m)/h## frequency is more likely to stimulate an emission than excite a transition of ##E_m->E_h## level (where ##E_m## is the mid level energy, and ##E_h## is the high level energy). Do I have this 100%?
Thanks,
KQ6UP
kq6up said:
the middle level to ground depopulates faster than the highest level to the middle level. Therefore, a a photon with ν=(Eh−Em)/hν=(Eh−Em)/h\nu=(E_h-E_m)/h frequency is more likely to stimulate an emission than excite a transition of Em−>EhEm−>EhE_m->E_h level (where EmEmE_m is the mid level energy, and EhEhE_h is the high level energy).
Yes, that's in fact the key point in the working of a laser through population inversion. Such situation must apply in all types of lasers, not only restricted to He-Ne laser.
Likes kq6up
Likes dlgoff
FAQ: Forbidden Transitions in the He-Ne Laser?
1. What are forbidden transitions in the He-Ne laser?
Forbidden transitions in the He-Ne laser refer to the energy level transitions between the helium and neon atoms that are not allowed by the selection rules of quantum mechanics. These transitions are typically associated with low energy and long wavelength light emissions.
2. Why are these transitions important in a He-Ne laser?
These forbidden transitions are important in a He-Ne laser because they are responsible for producing the red light emission that is commonly used in laser pointers and other applications. The low energy and long wavelength of these transitions make them ideal for creating a stable and efficient laser.
3. How are forbidden transitions in the He-Ne laser achieved?
Forbidden transitions in the He-Ne laser are achieved by exciting the helium and neon atoms with an electric discharge. This causes the atoms to move to higher energy states, and when they return to their ground state, they emit photons in the form of red light.
4. What factors influence the occurrence of forbidden transitions in the He-Ne laser?
There are several factors that can influence the occurrence of forbidden transitions in the He-Ne laser. These include the gas pressure, the temperature, and the current passing through the gas mixture. Higher gas pressure and temperature can increase the likelihood of these transitions, while higher currents can suppress them.
5. How do forbidden transitions affect the performance of the He-Ne laser?
Forbidden transitions can have both positive and negative effects on the performance of the He-Ne laser. On one hand, they are responsible for the red light emission that makes the laser useful for many applications. On the other hand, they can also cause instabilities and fluctuations in the laser output, which can affect its precision and accuracy.
