Force at an Angle: Solving for Acceleration & Normal Force
  • Thread starter Thread starter EnDev
    Angle Force
A 70 kg box is pulled across a frictionless surface by a 300 N force at a 30-degree angle to the horizontal. The acceleration of the box in the X direction is calculated to be 3.71 m/s². The normal force acting on the box is determined to be 536 N. The solution involves applying the correct physics equations to resolve the forces acting on the box. Understanding the components of the applied force is crucial for solving such problems.
EnDev
http://puu.sh/25OuR
a 70kg box is pulled across a frictionlesssurface by a 300N forace at an angle of 30 degree to the horizontal
A. What is the acceleration of the box in the X direction
b. what is the normal force on the box
not sure
Im not sure which formula to use on this one..
nevermind i figured it out.
A = 3.71 m/s
B 536
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
