Richg41
- 1
Hello: I am working on a machine for a non-profit to build homes in developing countries. I have laid out the basic machine concept and then became stuck trying to figure out how to open the 1000 lbs machine with only manual labor. The machine sits generally vertical with the opening side arms sitting at 15 degree off of vertical. The arms needs to travel through o degrees vertical then to -15 degrees for a total travel of 30 degrees. the pivot point is at the bottom of the arm, and the arm is 5' long.
I have an opportunity to use several levers to gain mechanical advantage but am not able to determine which lever provides the greatest advantage.
As can be seen by the diagram there are 3 points of interest.
a.) Simply pushing the arm open from the top; located 5' from the pivot point.
b.) A vertical lever arm that passes through the center of gravity, Called Lever 02.
c.) A lever are 4" above the pivot point, Called Lever 01.
May I ask for you help in determining what the forces need to be to open the machine arm at these three points?
Thanks,
Richhttp://sheltertheworld.org/pic/PBS.jpg
Thanks,
