Force on a Permanent Magnet Falling through a Coil
The discussion centers on the drag force experienced by a magnet falling through a coil compared to a conductive pipe. It is noted that a coil must be shorted to effectively induce currents, which creates a low-resistance loop and enhances the drag force. The formation of eddy currents in a conductive pipe produces significant drag, while the drag force in a coil is considered negligible. Participants express interest in optimizing coil length for power production, suggesting that a longer coil may be more beneficial despite the minimal drag force. Ultimately, the focus is on balancing drag force with the goal of maximizing power output.
BryanFantana
What is the drag force on a magnet falling through a coil? I have found several sources online describing the drag force on a magnet falling through a conductive pipe. How might this vary if a coil is used in place of a pipe? Does the coil need to be connected to a circuit to create this force?
The coil needs to be shorted for it to have an effect otherwise I don't think that the results differ that much.
I think this is pretty much correct. The magnet would like to induce eddy currents, and a large piece of metal allows currents to form in loops. This is why transformer, and motor cores are often laminated to reduce eddy currents. However, an open coil structure does not allow very big circular loops to form, and sort of acts like a laminated piece of metal, only better. Once, the coil is shorted, you have a very nice low-resistance loop! Perhaps, in this case, you would refer to the currents as generator currents, rather than eddy currents, since you now have a simple linear generator.
Thanks guys. From doing a little bit of lab testing and pondering, I gather that dropping a magnet down a conductive pipe produces lots of drag due to the Eddy currents forming inside the pipe. The same magnet falling down a coil experiences little drag and the drag force is probably negligible.
You guys mention shortening the coil. Would that lower the force? Ultimately the goal of my project is power production. I am trying to model how this thing might behave and I was curious about a magnetically-induced drag force. But since the force seems tiny and more power is the primary objective, would a longer coil be better?
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
