Force on an electron from a magnetic field
The discussion revolves around calculating the electrostatic force on a charged block in an electric field. The force calculated is 2.61E-1 N, but there is confusion regarding the angle relative to the positive x-axis. A suggestion is made to focus on the arctangent calculation without adding 180 degrees, as well as considering the direction of the force in relation to the electric field. Clarification is sought on the angle's definition, particularly whether it should be measured from the x-axis or another reference. Accurate interpretation of the force direction and angle calculation is crucial for solving the problem correctly.
brett812718
A 17.0 g block with a charge of +1.30 10-4 C is placed in an electric field e vector = (2000 i hat - 200 j hat) N/C.
(a) What is the electrostatic force on the block?
the force is 2.61E-1N but I am having trouble finding the angle.
F=qE
180+tan^-1(-200/2000)=174.3 degrees but webassign said it was wrong.
sorry the title should have said force on an electron from an elecrtic field
You might try writing only tan^-1 part (so you get like 6 degrees) and test this solution. Or use 90 instead of 180 deg... some diagram which angle are you looking for would be helpful.
I am looking for the angle made by F and the positive x axis
F is in the opposite direction of E right?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
