Forces acting on a block that is pushed against a wall
To move a block pushed against a wall, the applied force must exceed the frictional force. The calculations show that for upward motion, the force must be greater than 44N, while for downward motion, it must be less than 20N. The discussion concludes that the correct option is likely D based on these conditions. Participants agree that the calculations presented are accurate. Understanding the balance of forces is crucial for determining the block's movement.
MatinSAR
What should be the magnitude of force F so that the object is definitely moving?(Frictional force is equal to 0.5 for each newton of vertical force on the surface.)
A)25 B)30 C)40 D)50
##F_{net} =ma##
##f_{s} =µ_sN##
##f_{k} =µ_kN##
Picture of problem:
For the object to be moving, it must overcome friction.
##f=0.5*0.6F = 0.3F##
##mg=22N##
Upward motion:
##0.8F>mg+f \rightarrow 0.5F>22 \rightarrow F>44N ##
Downward motion:
##0.8F+f<mg \rightarrow 1.1F<22 \rightarrow F<20N ##
I think correct option is D. Can you please guide me if I'm wrong?
Your work looks good to me.
Thank you for your help.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
