Forces and Work on an Incline....
In summary, in this conversation, the question is discussed about a block on an incline at an angle above the horizontal. The block will travel from point A to B down the incline without friction. It is determined that the net force exerted on the block will remain constant as it travels, and the work done on the block by the normal force will be zero, while the work done by the weight force will be positive due to the angle between the force and displacement vector being less than 90 degrees.
Tim Wellens
The question is about a block on an incline at an angle Θ above the horizontal. The block will begin from the resting position and travel from point A to B down the incline. Neglect friction.
1) As the block travels from point A to B, will the magnitude of the net force exerted on the block increase, decrease, or stay constant?
2) For each force identified in your free body diagram, state whether the work done on the block is positive, negative, or zero
W=FdcosΘ
1) I think the net force on the block, as it travels from point A to B, would remain constant because the variables that make up the forces stay constant. I think there will be a constant net force exerted on the block until the block comes to a rest. I think this net force would be ΣF=mgsinΘ because ΣFy=n-mgcosΘ=0 due to the lack of movement in the y direction, which makes the net force ΣF=mgsinΘ. This net force I think would stay the same?
2) The forces that I listed that act on the block are the normal force and the weight force. The normal force would have positive work done, i think, because if we use W=FdcosΘ.. then the force is positive because it would be mgcosΘ.. The force and distance will be positive, as is the angle. Or is the distance 0 because the block isn't traveling at all in the y direction?
The weight force I'm confused on because you can break the weight force up into components, the y component is negative and the x is positive. So, I'm not sure if the work done by the weight force would be negative, positive or zero..
If the angle between the force and the displacement vector is 90 degrees, no work will be done because the cosine of 90 degrees is zero. Draw the displacement vector and the forces in your problem. Are any of them perpendicular to it? Similarly, if the angle between the force and the displacement vector is less than 90 degrees, the work done will be positive. Knowing these things now, would you like to modify any of your answers?
Oh, ok. So, the normal force will be zero because it's force is perpendicular to the displacement vector, and the weight would be positive because it's force vector makes an angle of less than 90 degrees with the displacement vector. So, we always use the weight without breaking it into components for figuring out the work? To figure out the net work I would add the work done by each of the forces, so in this case we only have normal force and weight force.. So the work would be positive because we only have zero work plus positive work, correct?
Yes, that's about right. I assume you meant the work done by the normal force is zero.
Whether you break the force into components is up to you. Sometimes it's easier that way. Should get the same result.
In your post #1, you seem to shift between Y being vertical and Y being normal to the plane.
I think Y is vertical to the plane and the forces in the y direction equal 0, while the forces in the x direction equal mgsinΘ.So, the net force is mgsinΘ. Is it correct that the net force would remain constant as the block travels from point A to B because the mass, gravity, and angle stay constant as the block travels? I can't think of any reason why it would decrease or increase.
You mean normal to the plane. Vertical is normal to the horizontal.
And it is whichever you choose it to be. It helps readers if you mention which you are choosing.
Yes.
Related to Forces and Work on an Incline....
What is an inclined plane?
An inclined plane is a flat surface that is tilted at an angle, allowing an object to be raised or lowered with less force than if it were lifted straight up.
What is the relationship between force and work on an incline?
The force required to move an object up an incline is less than the force required to move it straight up, but the distance over which the force must be applied is greater. Therefore, the work done is the same in both cases.
What is the formula for calculating work on an incline?
The formula for calculating work on an incline is W = Fd cosθ, where W is work, F is the force applied, d is the distance over which the force is applied, and θ is the angle of the incline.
How does the angle of the incline affect the work required?
The steeper the incline, the less force is required, but the distance over which the force must be applied is greater. Therefore, the angle of the incline affects the work required by changing the balance between force and distance.
What is the difference between work and power on an incline?
Work is the amount of energy required to move an object over a certain distance, while power is the rate at which work is done. On an incline, the same amount of work may require more or less power, depending on the angle of the incline.
