MHB Forces of 8N: Find Angle & Mass of Particle
The discussion addresses the calculation of the angle between two forces of 8N that result in a 13N resultant. The angle is determined using the formula θ = π - arccos((2 * 8² - 13²) / (2 * 8²)), or alternatively θ = 2arccos(6.5 / 8). Additionally, it is established that the mass of the particle is 2kg, derived from the equation 7N = mg - 13N, leading to mg = 20N with g set at 10 m/s². The acute angle that one of the 8N forces makes with the surface is given by φ = (π - θ) / 2. The calculations and methodology are confirmed as correct.
Shah 72
MHB
Two forces each of size 8N, have a resultant of 13N.
a) Find the angle between the forces
b) The two given forces of magnitude 8N act on a particle of mass m kg, which remains at rest on a horizontal surface with no friction. The normal contact force between the surface and the particle has magnitude 7N. Find m and the acute angle that one of the 8N forces makes with the surface.
Mathematics news on Phys.org
What have you done on this and where do you have a problem? Have you drawn the "force parallelogram" showing the addition of the forces?
Hi , thanks I got the answer.
(a) angle between the two 8N forces is
$\theta = \pi - \arccos\left(\dfrac{2 \cdot 8^2 - 13^2}{2\cdot 8^2}\right)$, or $\theta = 2\arccos\left(\dfrac{6.5}{8}\right)$
(b) $7\,N = mg - 13\,N \implies mg = 20\,N \implies m = 2kg$ (using $g = 10 \, m/s^2$)
$\phi = \dfrac{\pi - \theta}{2}$
Thank you so much!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
