Formation of accretion disk / frame drag
In summary, the concept of Frame dragging contributes to the formation of accretion disks around neutron stars and black holes. This has been observed in various studies and is considered a potential probe for frame-dragging effects in active galactic nuclei. Several papers have discussed this phenomenon and its impact on accretion disks, providing evidence for its existence and importance in understanding the behavior of these objects.
goldsax
51
came across the concept of Frame dragging.
i cannot find if this phenomena also aids in addition to the conversation of angular momentum the formation of an accretion disk around neutron stars/black holes.
cheers
Astronomy news on Phys.org
It seems clear that yes, Frame dragging does contribute to disk formation around supermassive black holes and active galactic nuclei. Here are some references:
THE ASTROPHYSICAL JOURNAL, 475:57 64, 1997 January 20
Line Emission from an Accretion Disk around a Rotating Black Hole: Toward a Measurement of Frame Dragging
BENJAMIN C. BROMLEY, 1 KAIYOU CHEN, AND WARNER A. MILLER
Theoretical Astrophysics Group, T-6, MS B288, Theoretical Division, Los Alamos National Laboratory, Los Alamos, NM 87545
Received 1995 December 15; accepted 1996 August 8
Excerpt from the “Discussion” section:
“For these reasons, we feel justified in choosing diagnostics of a line-emitting accretion disk as a probe for frame-dragging effects in the nuclei of active galaxies. As noted before (Laor 1991), perhaps the best hope of detecting the frame-dragging effect is to spot a stable Keplerian accretion disk at radii below the limit of 6Rg imposed in a Schwarzschild metric.”
(Note: This paper was written and published before Gravity Probe B positive results were announced.)
http://iopscience.iop.org/0004-637X/475/1/57/fulltext/33793.text.html
See section five:
“Frame-dragging: occurs generally around rotating objects. It's just that the exact
Kerr form only applies to black holes.”
www.astro.umd.edu/~miller/teaching/astr688m/lecture11.pdf
Disc Accretion in Active Galactic Nuclei
Andrew King
Theoretical Astrophysics Group, University of Leicester, Leicester LE1 7RH, UK
www.vlti.org/events/assets/3/documents/king.pdf
Four other possiblilities:
arXiv:1208.0728
Title: The effect of frame dragging on the iron K alpha line in X-ray binaries
Authors:Adam Ingram, Chris Done
arXiv:0705.1796
Title: Iron line profiles and self-shadowing from relativistic thick accretion discs
Authors:Sheng-Miao Wu, Ting-Gui Wang
arXiv:astro-ph/0401345
Title: Gravitating discs around black holes
Authors:V. Karas, J.-M. Hure, O. Semerak
arXiv:astro-ph/9901223
Title: Radiation force on relativistic jets in active galactic nuclei
Authors:Qinghuan Luo, R. J. Protheroe
thanks for the links...
Related to Formation of accretion disk / frame drag
1. What is an accretion disk and how does it form?
An accretion disk is a structure made up of gas and dust orbiting around a central object, such as a star or a black hole. It forms as a result of the gravitational pull of the central object on surrounding material, causing it to spiral inwards and form a disk due to conservation of angular momentum.
2. How does frame drag occur in relation to accretion disks?
Frame drag, also known as the Lense-Thirring effect, is a phenomenon in which the rotation of a massive object causes a dragging of spacetime around it. In the case of accretion disks, the rotation of the central object causes the surrounding material to also rotate, creating a frame-dragging effect.
3. What factors influence the formation of an accretion disk?
The formation of an accretion disk is dependent on several factors, including the mass and rotational speed of the central object, the density and composition of the surrounding material, and the temperature and pressure of the disk itself.
4. How do accretion disks play a role in the formation of planets?
Accretion disks are thought to be the birthplace of planets. As the material in the disk orbits and collides with each other, it gradually clumps together to form larger bodies. These bodies then continue to grow through collisions and gravitational attraction, eventually forming planets.
5. Can the study of accretion disks help us understand the evolution of our own solar system?
Yes, studying accretion disks can provide valuable insights into the early stages of planet formation and the evolution of our own solar system. By comparing the properties of accretion disks around other stars to our own, scientists can gain a better understanding of the processes that led to the formation of our planetary system.
  • Astronomy and Astrophysics
