I Formula For Calculating Field Angle (Beam Angle) of Light?
The discussion centers on the formula for calculating the beam angle of light, defined as α = 2 arcCos (1 - Lm ÷ (2 π Cd)), where Lm is luminous flux and Cd is luminous intensity. The beam angle indicates where the intensity of light falls to 50% of its maximum. Two key questions remain unanswered: the derivation of the equation Lm = 2 π Cd (1 - Cos (α ÷ 2)) and why it specifically applies to 50% intensity rather than 0%. Additionally, there is interest in the formula for calculating the field angle, where intensity drops to 10% of the maximum. The thread highlights a need for further clarification on these photometric concepts.
meeshu
There are actually several questions.
The formula for calculating the "beam angle" of light (emitted from lights bulbs, flashlights etc) is -
α = 2 arcCos ( 1 - Lm ÷ ( 2 π Cd ))
Where, α = beam angle in degrees
Lm = luminous flux (Lumens)
Cd = luminous intensity (Candela)
The above formula is simply a rearrangement of the equation -
Lm = 2 π Cd ( 1 - Cos (α ÷2) )
The beam angle formula above indicates the angle of light beam where the beam intensity falls off to 50% of the beam maximum intensity (apparently).
First question:
How is the equation Lm = 2 π Cd ( 1 - Cos (α ÷2) ) derived?
Second question:
How do we know that this equation applies only to 50% beam intensity?
There is another angle of light known as the "field angle", where the light beam angle is determined where the beam intensity falls to 10% of the maximum intensity. The field angle is greater than the beam angle.
Third question:
What is the formula for calculating light field angle?
Thanks for any and all constructive comments!
Mathematics news on Phys.org
Hi, meeshu, I'm afraid I cannot help you, haven't got idea. The Internet doesn't help you? YouTube, for example. Have you got PC, or just a mobile? Have you got a library near? Sorry, I cannot provide anything but questions. How did you acquired the background? Wouldn't you prefer to tackle one question, just to start moving?
Greetings!:smile:
Thanks for your comments.
I had already searched the internet before posting this topic. I didn't get satisfactory results from the searches at that time.
After more searches I believe the first question has been answered, courtesy of information from this
link here !
But from another equation,
Lumen = Candela x Steradian, where the solid angle steradian equals 2 π ( 1 - Cos (α ÷ 2) )
So the lumen equation becomes -
Lm = 2 π Cd ( 1 - Cos (α ÷2) ) as per the same equation mentioned in my first post.
But my second question as to why this equation only relates to beam intensity falling off to 50% instead of the entire beam intensity falling off to 0, has not been answered!
It is not clear why the equation only applies to 50% beam intensity?? That seems a bit odd!
In summary, to date, there are two remaining questions yet to be answered -
Why does the equation only apply up to 50% beam intensity?
And, what is the equation for calculating light beam "field angle" where the beam intensity falls down to 10% of the initial (maximum) beam intensity?
Maybe these questions should be in a "photometric" or similar sub-forum, but I don't think there is such a sub-forum here(?)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
