I Formula for maximum angular frequency and velocity
The formula Vmax = Wmax x L describes the maximum speed of a pendulum bob, where Wmax represents the maximum angular speed. The equation can be interpreted as Vmax = ωmax x L, with ωmax being the maximum angular speed and L the length of the pendulum. The second equation, Wmax = Wθmax, involves two different definitions of angular speed, with ωmax indicating the rotation rate at the bottom of the swing and ω representing the angular frequency of oscillations. The discussion highlights the confusion arising from the notation and suggests a clearer representation of the relationship between angular speed and deflection angle. Understanding these formulas is essential for analyzing pendulum motion effectively.
MenchiKatsu
TL;DR Summary
I can't seem to find it anywhere
What does this formula mean ? I can't find it anywhere. Vmax=Wmax x L. And Wmax=Wθmax. It came up in the pendulum chapter. L is string length.
I can imagine that Vmax=Wmax x L is actually ##V_{\text{max}}=\omega_{\text{max}}L## where
##V_{\text{max}}=~## maximum speed of the pendulum bob
##\omega_{\text{max}}=~## maximum angular speed of the pendulum relative to the point of support
##L=~## the length of the pendulum.
I cannot imagine what Wmax=Wθmax could be.
$$\omega_\text{max} = \omega \theta_\text{max}$$I will make a guess at this one. The notation is confusing because there are two different omegas (##\omega##) being considered here.
On the left hand side of the equality we have ##\omega_\text{max}## which is the rotation rate (in radians per unit of time) for the pendulum at the bottom of its swing.
On the right hand side of the equality we have ##\omega## which is the angular frequency of the oscillations of the pendulum.
Finally we have ##\theta_\text{max}## which is the maximum deflection angle of the pendulum from the vertical.
For instance...
If we have a one meter pendulum under earth gravity, its period is about two seconds. This is an angular frequency (##\omega##) of about ##2 \pi## radians per ##2## seconds. Or about one radian per second.
If this pendulum is launched from rest at a deflection angle (##\theta_\text{max}##) of ##0.1## radians from the vertical, the equation asserts that the rotation rate (##\omega_\text{max}##) of the pendulum at the bottom of its arc will be ##0.1## radians per second.
Likes MenchiKatsu and kuruman
jbriggs444 said:
I will make a guess at this one. The notation is confusing because there are two different omegas (ω) being considered here.
I agree. It should be something like $$\omega_{\text{max}}=\theta_{\text{max}}\sqrt{\frac{g}{L}}$$ where ##\omega## is a reserved symbol for the angular speed of the pendulum bob.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
