Four Protons Are Fused Into An Alpha Particle, Energy Released
The discussion centers on the fusion of four protons into an alpha particle and the energy released during this process. A user initially miscalculated the energy by incorrectly multiplying by c², which was later corrected. The calculations involve the binding energy of the particles and the conversion of released energy into electrical power for a hypothetical fusion power plant. The final correct answer for the number of alpha particles needed to be fused per second is approximately 1.87 x 10²¹. The conversation emphasizes the importance of accurate unit conversions and calculations in nuclear fusion scenarios.
breakingaway
(answered)Four Protons Are Fused Into Alpha Particle, Energy Released
Answered: I wasn't supposed to multiply by c2. Thank you ehild
I apologize in advance if I posted this in an incorrect format or in the wrong section. I read the rules and I believe this is the correct format/place.
The proton-proton reaction that takes place in the Sun has the net effect of converting four protons (Mp= 1.007825 u) into alpha particles (Ma= 4.002603 u). The resulting "released" energy is shared between the kinetic energy of the alpha particles, positrons, neutrinos and gamma ray photons. Assume we could eventually design a 1.00 GW (billion watt) fusion power plant using this same reaction. Also assume that 12.5% of the "released" energy (kinetic + photon) can be converted into electrical power.
How many alpha particles would need to be fused in the reactor every second?
binding energy:
[STRIKE]Eb=c2 * (Mnucleons-Mparticle)*931.494MeV[/STRIKE]
Eb=(Mnucleons-Mparticle)*931.494MeV/u
Eb = c2 * (4*Mp-Ma)=2.2058*1024eV =3.85408*105j
Eb*12.5% = 4.8115*104j
1*109W / Eb = 2.0783*104s-1
The correct answer is: 1.87*1021
Thank you in advance for any help anybody can provide.
In what units of mass have you calculated with? ehild
For the problem the mass of a proton(1.007825u) and alpha particle(4.002603u) is given in atomic mass units(u=931.494MeV). I converted to joules before doing any calculations involving power.
Why did you multiplied energy by c^2?
ehild
ehild
Well, I think you just found my mistake.
Just crunched the number without the c^2 and it came out correct.
Thank you.
Yes, taking the proton mass in kg-s, m(proton)c2/(1.6 10-19(J/eV) )≈931 MeV.
ehild
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
