B Four Velocity Sign of Time: \dot t>0?
Onyx
TL;DR Summary
Is it generally the case even with light like paths that ##\dot t>0##?
A four velocity is not defined for a light like path.
Up to you, really. It is true that all future-pointing vectors will have the same sign in their time component, assuming your time coordinate is reasonably named and the spacetime has a global distinction between past and future. But there's nothing to stop you having your time coordinate increase towards the past, in which case all future-pointing four vectors would have negative time components.
As @Sagittarius A-Star points out, four velocity is not defined for null paths. However, you can define other four vectors tangent to null curves, such as the four momentum.
Likes topsquark and PeterDonis
It's convenient to have the world-line parameter defined such that ##\dot{t}>0##. For massive particles you have time-like worldlines, and you can choose the proper time, ##\tau## as a natural world-line parameter. Then the four-velocity is "normalized": ##u_{\mu} u^{\mu}=c^2##.
For massless particles ("naive photons") of course you cannot choose proper time, because it's not defined but you can choose any affine parameter you like. Then you have ##\dot{x}^{\mu} \dot{x}_{\mu}=0##, i.e., light-like worldlines.
In both cases it is natural to choose ##\dot{t}>0##, where ##t## is the time-like coordinate since then with increasing world-line parameter you describe a motion into the future.
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
