Fourier Series Problem: Finding Coefficients for Piecewise Function f(t)
Drake25
one period of a function f(t) is given by the piecewise function f(t)= 2t if -pi/2 <t <0 and -1 if 0< t < pi/2
I need to find a sub 0, a sub n, a sub 1,2,3,& 4, and b sub 1,2,3 &4
If I could just get a sub 0 the rest are easy, however, my answer does not look correct.
a sub 0= 1/p * integral from p to -p f(t)dt
a sub n= 1/p * integral from p to -p f(t)cos (n*pi*t)/p dt
b sub n is the same except sin replaces cos
I worked through the equation for a sub o and got -pi/2 -1
Now, it's the -1 that I don't think belongs? But i don't know for sure if it is wrong but if it is that will mess up all of the other answers. I just wish someone could explain to me how I have done it wrong. Thank you!
\int_{0}^{\frac{\pi}{2}}{-1dt} is -\pi/2, not -1.
Also keep in mind that the equations as you've written them are wrong; either you want a 1/2p in the beginning or you want to integrate from -p/2 to p/2. The point is to divide by the "length of integration", but if you integrate from -p to p that length is actually 2p. a_0 should represent the average value of the function on that interval.
ok, that makes sense! thank you!
i wish my computer would allow me to type symbols like you did, where can i find those so that my question is easier to read?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
