I Fourier Transform of Photon Emission Hamiltonian
thatboi
Hey all,
I just wanted to double check my logic behind getting the Fourier Transform of the following Hamiltonian:
$$H(x) = \frac{ie\hbar}{mc}A(x)\cdot\nabla_{x}$$
where $$A(x) = \sqrt{\frac{2\pi\hbar c^2}{\omega L^3}}\left(a_{p}\epsilon_{p} e^{i(p\cdot x)} + a_{p}^{\dagger}\epsilon_{p} e^{-i(p\cdot x)}\right)$$
and ##\epsilon_{p}## is the polarization vector and ##a_{p},a_{p}^{\dagger}## are the photon creation/annihilation operators for a photon with momentum ##p##. Also, we can treat the ##p## and ##x## as 4-vectors. To transform ##H(x)## to the momentum basis, I insert an integral of ##d^{4}x## and multiply by ##e^{ik\cdot x}##. Doing this leaves me with $$H(k) \propto \delta(p-k)k$$ since the ##\nabla_{x}## drags down a factor of ##k## and the Fourier Transform of an exponential function is just a Dirac delta. This result seems too simple to me so I was wondering if I made a mistake somewhere.
Thanks.
What happens to ##A(x)## when you do the integral? It seems like you're just leaving it out.
I thought the ##\delta(p-k)## factor came from the ##e^{(ip\cdot x)}## term in ##A(x)##, in which case I also forgot a ##\delta(p+k)*k## factor in my above response.
Let me try to say what @PeterDonis said but slightly more direct. Where are ##a_p## and ##\epsilon_p##? Also, the expression you give for ##H(k)## is proportional to ##k##, and ##k## is generally a vector. Your sanity check alarms should be going off.
Perhaps you should fill in the steps (using, say, mathematics
thatboi said:
A(x)=2πℏc2ωL3(apϵpei(p⋅x)+ap†ϵpe−i(p⋅x))
and ϵp is the polarization vector and ap,ap† are the photon creation/annihilation operators for a photon with momentum p. Also, we can treat the p and x as 4-vectors. To transform H(x) to the momentum basis, I insert an integral of d4x and multiply by eik⋅x. Doing this leaves me with
Hand waving is not enough. It is good that your radar went off. It is bad that you didn't do the physics.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
