Frame of reference - forces in a turn (airplane)
The discussion centers on two different depictions of forces acting on an airplane during a turn. One image illustrates unbalanced forces from a stationary reference frame, indicating that the airplane accelerates towards the center of its turning radius. The second image presents a balanced force scenario from a rotational reference frame, suggesting that the airplane is stationary relative to that frame while still rotating. Participants debate the usefulness of analyzing acceleration in a non-inertial frame, questioning the relevance of balanced forces when discussing actual airplane dynamics. Ultimately, the conversation highlights the complexities of understanding forces in different reference frames and their implications for pilots.
italia458
Hi,
I've seen the forces in a turn depicted two different ways:
http://selair.selkirk.ca/Training/Aerodynamics/images/lf-turn.gif
http://www.free-online-private-pilot-ground-school.com/images/forces_during_turn.gif
Which one is correct?
I think the first one would be since it's analyzing it from one reference frame and the second picture appears to analyze it from multiple reference frames.
Regarding the second picture: if the forces are all balanced (as depicted), the airplane wouldn't be accelerating. How can it turn then?
Cheers!
I think the second picture is merely showing how the centripetal force increases in a sharper turn, where the plane is banked more. IMO, both pictures show the same thing, only slightly different.
italia458 said:
Hi,
Cheers!
The first picture shows unbalanced forces and it says "Force of centripetal acceleration" centripetal means "towards the center" if I recall. So, the plane is accelerating towards the center of the axis of its turning radius. The frame of reference, in this case, is stationary, from the ground, or a stationary observation tower, looking towards the airplane in that instant that it was facing away from the viewer.
The second picture is from a rotational reference frame. The forces are balanced, in this case, because it is a non inertial reference frame. The forces are balanced, but in relation to a reference frame that is already rotating. The airplane is "stationary" relative to the rotational reference frame, but is still rotating. A centrifugal force is mentioned, so, in this case, it means "from the center." Relative to the rotational reference frame, the forces the plane experiences are trying to push it away from the axis of rotation.
At least, that's how I interpret it.
Is there any benefit for a pilot to see acceleration relative to a rotational reference frame... that is rotating at the same velocity as the airplane?! Meaning zero acceleration. To me it seems at least useless and just wrong, in some way.
How do you know which forces the airplane is "experiencing"? I thought all the forces drawn on that airplane were what it was experiencing. If that's correct, then it's experiencing a force away from the axis of rotation (as you stated) but it's also experiencing a force towards the axis of rotation (centripetal force) and they're equal and opposite.
I understand that if you decide to have your reference frame move in the exact path of your object then there isn't any acceleration. But what's the point of that? Every force would be always balanced then and there would never be acceleration.
The point of the second picture is to show the resultant load or "g-force" experienced by the airframe.
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
