Free Body Diagram Help: Homework Equations and Attempts
The discussion centers on understanding reaction forces in a free body diagram (FBD) involving a beam and various applied forces. The professor emphasizes the importance of identifying whether the beam is preventing movement in any direction, which would necessitate including reaction forces in the FBD. The participant's FBD lacks the internal force from the beam at joint B and needs to break down external forces into their x and y components. It is suggested to first determine the reaction forces at points A and C using equilibrium equations, noting that the reaction force at C aligns with the cable direction. The weight of the beam is assumed negligible, indicating that there should be no upward force at A in this pure truss scenario.
USN2ENG
I feel that I am a bit fuzzy whether things are reaction forces. In the diagram I see there is a beam holding point B, and there are 3 forces: Cable BC, 500N, and 780N.
My professor wrote:
Ask yourself: is the beam holding the point from moving up or down, right or left? If so you will need to include the appropriate reaction forces in your FBD.
To me, it is, as the beam is not hinged. Unfortunately I am not quite sure how to handle how to label the reaction force. Any advice would be great!
My FBD is attached.
At A, the reaction force is Upwards
When you draw a FBD of joint B, you must include ALL forces, both external and internal, acting on the joint. You neglected to include the force of the beam acting on the joint. You should also break down the applied external forces at B into their x and y components.
It is often best to find the reaction forces at A and C first, by using the 3 equilibrium equations and noting that the reaction force at C must be directed along the cable direction BC.
I don't see any reference to the weight of the beam, so I assume it is negligible, in which case there cannot be any upward force at A, since this is a pure truss with axial tensile or compressive forces only, in the cable and beam.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
