How Do You Balance Forces in a Bicycle Free Body Diagram?
In summary, the author is working on figuring out how to balance an 800 N force on a pedal with a rider applying weight to it. There are different situations that must be considered.
ultra york
Bicycle with a rider applying weight to on pedal. Draw as free bodies in equilibrium. There are different situations.
N/A
So I am working on part a).
1. I believe it is only referring to just the pedal, chain, and the two smaller circles of the (sprocket??).
2. Assuming that is correct to balance the 800N there would need to be an opposing force, is this the torque that is created on the smaller rear circle or is it just as simple as an opposing force in the left side of the pedal?
"Pedal, crank and pedal sprocket assembly" aren't standard bicycle terminology. For clarity it should be pedal, crank and chainring. The pedal is where the 800N is applied at the end of the 160mm crank arm opposite its attachment to the 100mm radius chainring. The 800N force is resisted by the resultant tension force in the top/power run of chain.
The smaller circle at the left end of the top chain is the "cog(wheel/set)" where the top chain tension force times the cog radius creates the torque moment on the rear wheel.
The bottom return run of chain is slack.
N/A
Hello, and welcome to the Forum, ultra york!
Since the system is in equilibrium, all forces and torques must be equal to zero.
So to begin with, you should list, under "Relevant equations", the equation for torque.
It looks to me as though the 800 N force on the pedal is going to create a clockwise torque around the axis of the "pedal sprocket assembly", so you will have to figure out a force at the perimeter of the sprocket that produces a counter-clockwise torque of equal magnitude.
Since bicycles are a bit weird, I've taken the liberty of drawing the FBD for you.
You can effectively ignore all aspects of the chain, except for the "point of interest".
So to more fully answer your questions, forget about the smaller rear circle/sprocket/cog for now.
Until you get to part b, it's irrelevant.
I would like to clarify that there are a few different situations that could be considered when drawing a free body diagram of a bicycle with a rider applying weight to one pedal.
Firstly, it is important to define the system of interest. In this case, the system would include the bicycle, rider, and the ground the bicycle is resting on.
Now, in order to draw a free body diagram, we need to identify all the external forces acting on the system. These would include the weight of the bicycle and rider, the normal force from the ground, and the force applied by the rider on the pedal.
In the situation where the rider is applying weight to only one pedal, we would see a torque being created around the axis of the pedal. This would be due to the force applied by the rider on the pedal, which would be countered by an equal and opposite force from the ground. This torque would also be countered by the torque created by the weight of the bicycle and rider on the opposite pedal.
In order for the system to be in equilibrium, the sum of all the forces in the horizontal and vertical directions must be zero, and the sum of the torques must also be zero. This would result in a balanced free body diagram, with the forces and torques cancelling each other out.
However, it is important to note that there are other situations that could be considered, such as when the rider is standing on the pedals or when the bicycle is in motion. In these cases, there would be additional forces and torques to consider, and the free body diagram would look different.
In conclusion, drawing a free body diagram of a bicycle with a rider applying weight to one pedal requires careful consideration of the system and all external forces and torques acting on it. It is important to be clear about the specific situation being considered in order to accurately represent the forces and torques involved.
FAQ: How Do You Balance Forces in a Bicycle Free Body Diagram?
What is a Free Body Diagram (FBD) of a bicycle?
A free body diagram is a visual representation of all the forces acting on an object. In the case of a bicycle, it shows the forces acting on the different parts of the bicycle, such as the pedals, wheels, handlebars, and frame.
Why is a FBD important when studying bicycles?
A free body diagram allows us to analyze the different forces and their directions on a bicycle, which is crucial in understanding the overall motion and stability of the bicycle. It also helps in identifying any potential weak points or areas of improvement in the design of the bicycle.
What are the different forces shown in a FBD of a bicycle?
The main forces shown in a FBD of a bicycle are the weight of the bicycle and rider, the normal force from the ground, the frictional force between the tires and the ground, and the forces applied by the rider through the pedals and handlebars.
How can a FBD help in improving the performance of a bicycle?
By analyzing the forces shown in a FBD, engineers and designers can make adjustments to the design and materials used in the bicycle to optimize its performance. For example, by reducing the weight or increasing the normal force, a bicycle can become more efficient and easier to ride.
Can a FBD be used to analyze the stability of a bicycle?
Yes, a FBD is essential in understanding the stability of a bicycle. By analyzing the forces acting on the bicycle, engineers can determine the center of gravity and make adjustments to improve the overall stability and handling of the bicycle.
