Free fall from rest at a particular radius to the central singularity
happyparticle
Proper time from rest at a particular radius to the central singularity
Eddington–Finkelstein coordinates
##ds^2 = - (1-\frac{2M}{r}) dt^2 + 2dtdr +r^2 d\Omega^2##
I have this problem:
First of all, I would like to have an equation for the proper time.
I was using the Eddington-Finkelstein coordinates in the Schwarzschild metric : $$ds^2 = - (1-\frac{2M}{r}) dt^2 + 2dtdr +r^2 d\Omega^2$$
Knowing that the observer falls radially, thus ##d\phi = d\theta = 0##.
Also, ##ds^2 = -d\tau^2 ## and after a little algebra we get:
$$1 = (1-\frac{2M}{r}) (\frac{dt}{d\tau})^2 - 2 \frac{dt dr}{d\tau^2}$$
I'm pretty stuck here. I found here and there that the equation for the proper time in this situation should be ##\tau = \frac{\pi r_0^{3/2}}{2\sqrt{2M}}##.
I guess I need to find the value for ##\frac{dt}{d\tau}##.
OK
You can get an expression for ##\frac{dt}{d\tau}## by noting that free fall is motion along a geodesic. The equations of motion for a geodesic can be found using a variational principle. For example, see the first page of these notes. Here, they are working in Schwarzschild coordinates and arrive at the bottom of the page with an expression for ##\dot t \equiv \dfrac {dt}{d \tau}##. You can apply the same method when using Eddington-Finkelstein coordinates.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
