A Free Simulator Software for Vacuum Field BVPs | Tom
TGlad
Hi, I am interested in simulating the vacuum field equations, but solving a full boundary value problem rather than the initial value problem. i.e. I might have boundary conditions in all spatial and temporal extents/extremes, rather than just an initial 3D surface.
Does anyone know any free software that could perform such a simulation? I have started looking at the Einstein Toolkit docs and it doesn't really look like it does this, and I don't have much info on GRCombo.
many thanks,
Tom.
Well, I have no experience with numerical relativity, however, specifying all boundary conditions on all extremes need not be consistent, right? Doesn't sound like a well posed problem numerical issues aside.
It seems quite likely I would be over-constraining the vacuum equations, in which case I would need to provide fewer constraints, or allow for the solution closest to a vacuum rather than pure vacuum. But basically I'm after a solver that doesn't solve the usual initial value problem forward in time, but instead solves a boundary value problem for the whole 3+1 block.
It is totally OK if no-one has any recommendations, that is in itself helpful information.
The point that @Paul Colby was suggesting (which I think is valid) is that any attempt to go beyond providing initial value conditions will be over-constraining the equations. Knowing the initial values is already sufficient to constrain the boundary value problem for the whole 3+1 block.
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
