emilmammadzada
- 109
- 18
- TL;DR Summary
- FRENDY nuclear code instaling problem
I want to compare njoy2016 and frendy codes.If anyone is using frendy nuclear, I wanted to get information about how to download it for ubuntu 22.04 version?
emil@DESKTOP-:~/frendy_20220126/frendy/main$ ls
Makefile libfrendy.a_m main_frendy.d remove_old_object_file.sh
frendy.exe main_frendy.cpp main_frendy.o_m
I will try to run the exe file using wine in WSLAlex A said:All I can offer is one of the repositories I found in the search has some scripts for processing JENDL with FRENDY,
https://github.com/AI-Pranto/triga-dataLibrary
2.3 How to Execute FRENDY
The execution command is
frendy.exe “input file name”
The input file name is set as a command-line argument
I tried to run the application and got this resultAlex A said:All I can offer is one of the repositories I found in the search has some scripts for processing JENDL with FRENDY,
emil@DESKTOP-:~/frendy_20220126/frendy/main$ ./frendy.exe test.inp
FRENDY calculation date : 2023/02/18 03:25:30
Version : 2.00.000 (2022/Jan/26)
Developed by Japan Atomic Energy Agency++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
=== Input file information (original) ===
Input file name : test.inp
//Input file of FRENDY for continuous-energy neutron data
ace_fast_mode //processing mode (generate fast ACE file) //Nuclear data file name
nucl_file_name U235.dat
/* ace file name */
ace_file_name U235.ace
temp 296.0 // temperature [K]
add_grid_data (0.625 4.0) //Additional energy grid point
sigima_zero_data //sigma-infinity is 1.0E10 [b]
(1.0E10 1.0E06 1.0E05 1.0E04 1.0E03 1.0E02
3.5E02 1.0E02 1.0E01 1.0E-1)++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
=== Input file information (without comment) ===
ace_fast_mode
temp 296.0
sigima_zero_data
=== Read input data for ReconResonance ===
nucl_file_name : U235.dat
add_grid_data [eV]
1 / 2 : 0.625
2 / 2 : 4.0
=== Read input data for DopplerBroadening ===
temp [K] : 296.0
=== Read input data for GasProduction ===
=== Read input data for ProbTable ===
=== Read input data for ThermalScatter ===
=== Read input data for AceDataGenerator ===
ace_file_name : U235.ace
* !!! FATAL ERROR !!! *
<Class name>
FrendyInputReader
<Function name>
check_not_used_input_data(vector<vector<string> >& input_data)
<Error message>
Input type : sigima_zero_data
Input data (Number of data : 10)
1 / 10 : 1.0E10
2 / 10 : 1.0E06
3 / 10 : 1.0E05
4 / 10 : 1.0E04
5 / 10 : 1.0E03
6 / 10 : 1.0E02
7 / 10 : 3.5E02
8 / 10 : 1.0E02
9 / 10 : 1.0E01
10 / 10 : 1.0E-1
This input type is not used for ace_file_generation_fast_mode.
Please check the calculation mode or input type.
terminate called after throwing an instance of 'std::runtime_error'
what(): Runtime error. Please check your input file or source file.
Aborted
You can download the FRENDY nuclear code from the official website of the Japan Atomic Energy Agency (JAEA) or from repositories provided by institutions that support nuclear research. Make sure to follow the official guidelines and licensing agreements when downloading.
Yes, the official repository for FRENDY nuclear code is typically provided by JAEA. You should check their official documentation or contact their support to get the most up-to-date information on compatible versions and repositories.
The system requirements for installing FRENDY on Ubuntu 22.04 include having a 64-bit version of Ubuntu, sufficient RAM (at least 4GB), and enough disk space to accommodate the software and its dependencies. Additionally, you may need to install certain libraries and development tools as specified in the installation manual.
Yes, before installing FRENDY, you need to ensure that you have the necessary development tools and libraries installed. This may include compilers like GCC, build tools like CMake, and specific libraries required by FRENDY. Refer to the official installation guide for a detailed list of prerequisites.
Yes, there is official documentation and user guides available for installing and using FRENDY. These can be found on the JAEA website or through the repository where you download the code. The documentation typically includes step-by-step installation instructions, usage examples, and troubleshooting tips.
