Frequency Comb (Photonics, Optics)
  • Thread starter Thread starter Astronuc
A frequency comb is a unique light source featuring multiple colors arranged in an orderly pattern, resembling a rainbow, with bright frequencies appearing as spikes on a spectrogram. This technology allows for the simultaneous transmission of multiple data streams without interference, as each frequency acts as an independent channel. Recent advancements in Michal Lipson's lab focused on enhancing LiDAR technology led to the creation of frequency combs using high-power multimode laser diodes integrated into silicon photonics chips. The engineering challenges involved in this integration are significant due to the small dimensions of the light pathways. The ongoing research highlights the potential of frequency combs in various applications, including medical devices and precision measurement technologies.
Astronuc
Staff Emeritus
A frequency comb is a special type of light that contains many colors lined up next to each other in an orderly pattern, kind of like a rainbow. Dozens of colors—or frequencies of light—shine brightly, while the gaps between them remain dark.
When you look at a frequency comb on a spectrogram, these bright frequencies appear as spikes, or teeth on a comb. This offers the tremendous opportunity of sending dozens of streams of data simultaneously. Because the different colors of light don't interfere with each other, each tooth acts as its own channel.
https://phys.org/news/2025-10-powerful-precise-multi-lasers-chip.html
All one needs is the right materials, junctions and optics.
A few years ago, researchers in Michal Lipson's lab noticed something remarkable. They were working on a project to improve LiDAR, a technology that uses lightwaves to measure distance. The lab was designing high-power chips that could produce brighter beams of light.
"As we sent more and more power through the chip, we noticed that it was creating what we call a frequency comb," says Andres Gil-Molina, a former postdoctoral researcher in Lipson's lab.
The breakthrough started with a simple question: What's the most powerful laser we can put on a chip?
The team chose a type called a multimode laser diode, which is used widely in applications like medical devices and laser cutting tools. These lasers can produce enormous amounts of light, but the beam is "messy," which makes it hard to use for precise applications.
Integrating such a laser into a silicon photonics chip, where the light pathways are just a few microns—even hundreds of nanometers—wide, required careful engineering.
Andres Gil-Molina et al, High-power electrically pumped microcombs, Nature Photonics (2025). DOI: 10.1038/s41566-025-01769-z
While not a frequency comb, a YouTube video explained how Disney lost a critical optical splitter that enabled them to create some amazing effects (examples include Mary Poppins, where the characters dance in front of fanciful scenery with no blur) that current technology cannot achieve.
The individuals in the video managed to reconstruct the lost technology, which Disney used, featuring sodium lamps that emitted a specific frequency of light.
Essentially, it's related to a single-tooth comb.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
