Frequency Multiplier problem for a guitar tuner
  • Thread starter Thread starter steveyesterda
    Frequency Guitar
A physics student is designing a guitar tuner circuit that uses a microphone and low-pass filters to isolate string frequencies. The current frequency counter setup only achieves a sensitivity of 1Hz, which is inadequate for tuning accuracy; the goal is to measure frequency to two decimal places. The student is considering using a phase-locked loop (PLL) for frequency multiplication but lacks clarity on the necessary components. Suggestions include using a higher-frequency crystal oscillator or exploring existing frequency counter schematics for better accuracy. The discussion emphasizes the need for precision in tuning, as human perception can detect frequency differences as small as 0.25Hz.
steveyesterda
hello everyone
I am a physics student who is currently writing his dissertation on designing a guitar tuner.
So far I have designed my circuit to have a microphone that inputs the sound played from the string. Then a 6 way switch connected to low-pass filters filters out the unwanted higher harmonics. I have used a crystal oscillator at 32768Hz and divide it down to give me my 1 second pulse and used a commparator to change my input string frequency to a square wave.
The problem I am having is with the +/-1 count ambiguity of a frequency counter of this style. Currently, if I were to count that signal I would only be able to determine the unknown frequency to 1Hz, not accurate enough for a guitar tuner. I need to be counting to 2 decimal places, so my plan was to multiply this frequency by 100, but this is where I become stuck.
I have tried researching using a PLL (phase-locked loop) but I don't really understand which components and values I need to get this to work. Can someone please help me. :(
Or if anyone knows of an IC that would do this job for me, that would be even better! I have looked at this frequency multiplier
http://parts.digikey.com/1/parts/1174449-ic-pll-freq-multiplier-28-tssop-sn65lvds150pwr.html
but i don't know if that will give me the desired multiplication or if it i would need to add any other components to make this work.
Thanks PhysicsForum, any help is much appreciated.
1hz sensitivity is enough, I think.
commertial tuners are sensitive to about 0.5 hz.
1 hz is fair for an amateur design.
hey, thanks for your reply.
Problem is, i have stated already that the human ear can tell the difference in frequency of about 5cents which on the low E string of a guitar corresponds to about 1/4Hz, an accuracy I need to be able to replicate.
Is there not a simple way to just increase the frequency x10 twice?
Thanks
steveyesterda, cool project.
It sounds like you're on the right track.
Of course, you could get to 1/4 Hz accuracy by triggering on the up and down portions of the square wave then sampling for 2 seconds, but I suppose you want even better than 1/4 Hz (plus faster sampling). PLL sounds like the way to go, I don't know component specifics, but there's got to be sample frequency counter (essentially what you're building) schematics out there. Best of luck, steveyesterda.
Rather than use a PLL (and being completely ignorant of your design) can you just use a higher-frequency crystal for your time-base? Even the internal oscillator of most microcontrollers can be calibrated fairly well, assuming fairly consistent voltage, and temperature.
EDIT: And welcome to PhysicsForums!
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
