Frequency to wavelength question (thermal Doppler broadening)
  • Thread starter Thread starter dartingeyes
The discussion centers on the relationship between frequency and wavelength, particularly in the context of thermal Doppler broadening. It clarifies that the equation \(\nu = c/\lambda\) does not directly apply to small variations in frequency and wavelength. The derivation shows that the product \(\omega\lambda\) remains constant, leading to the relationship \(\Delta\lambda/\lambda \simeq -\Delta\omega/\omega\). This highlights the importance of understanding variations rather than just the static relationship between frequency and wavelength. The clarification is essential for grasping the nuances of Doppler broadening effects.
dartingeyes
I don't understand how to go from one equation to the other
provided in picture
I want to understand how the two equations in the picture are the same. I am confused because \nu=c/\lambda. This would mean that the term on the right side of the equation in the square root, call it x, would then become x^-1. The resulting equation being \Delta\lambda = \lambda x^-1. But somehow this is not the case?
What you are saying is only true for the relationship between frequency and wavelength themselves - not their small variation.
From ##\omega \propto 1/\lambda## follows that ##\Delta\omega \propto \Delta\lambda /\lambda^2 \propto \Delta\lambda (\omega/\lambda)##.
Thank you. This tracks for me.
A somewhat cleaner derivation:
The product ##\omega\lambda## is constant so ##0=\Delta(\omega\lambda) \simeq \omega \Delta\lambda + \lambda\Delta\omega##. This directly leads to ##\Delta\lambda/\lambda \simeq - \Delta\omega/\omega##.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
