I Friction Coefficient of Marble & Iron on Plastic
The friction coefficient between marble and plastic, as well as iron and plastic, varies based on the type and surface finish of the materials involved. Published data on these coefficients is scarce, making it necessary to conduct personal measurements. The recommended method involves tilting a flat piece of one material until the other slides down, then calculating the tangent of the angle to determine the friction coefficient. This approach is straightforward and can yield accurate results. For further exploration, searching "measure friction coefficient with ramp" can provide additional insights.
xWaldorf
hey, i was looking for information on friction coefficient of marble on plastic and iron on plastic.
if you know these values i'll be very glad!
thanks in advance
The friction coefficient depends on the type of plastic, the surface finish of the plastic, and the surface finish of the marble or iron. It may depend on the contact pressure. Do not expect to find any usable published information.
This is a case where you need to measure it yourself. Fortunately, it is an easy test. You take a flat piece of one material, set a piece of the other material on it, tip the flat piece until the other piece sloowwly slides down, then measure the ramp angle. The tangent of that angle is your friction coefficient. Good search term for deeper discussion is measure friction coefficient with ramp.
Likes berkeman, Lnewqban and hutchphd
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
