B Friction on pure rolling non deforming sphere?
Friction on a purely rolling, non-deforming sphere on a horizontal surface primarily involves the dynamics of contact points. As the sphere rolls, it has only one contact point at any moment, which continuously changes, resulting in zero velocity at that point. While there is no rolling resistance due to the lack of deformation, air resistance will eventually slow the sphere down. The discussion highlights that friction is independent of contact area and pressure, depending instead on the total contact force. Ultimately, the interaction between a frictionless sphere and a frictionless surface raises questions about the nature of friction itself.
tbn032
How will the friction work on a sphere which is purely rolling on a horizontal surface such that both the sphere and surface does not deform. The sphere at any time t will only have one point of contact, which would continuously changing as the sphere rolls. Will The friction be applied to the sphere and will it stop rolling?. Since there is one point of which pass vertically through the center of mass, there would not be any counter torque due to normal forces. The velocity of contact point would be zero since it is pure rolling.
If the sphere and surface are not deforming, there is no rolling resistance, right? So you are only left with some air resistance opposing the sphere's linear movement, which will eventually slow the sphere to a stop.
True, but for a finite contact force, the pressure at the point of contact would be infinite, and so beyond the strength of any real material. Friction is independent of the area of contact or pressure. Friction is proportional only to the total contact force.
It is the locus of the contact point that moves as the object rolls, not the contact point. In your ideal geometric model, each contact point exists for only one instant. Without time, the contact point cannot have a velocity, but the locus of all the instant contact points does have a velocity.
You mean "how does friction work between a frictionless object and a frictionless surface?"
Likes sophiecentaur and berkeman
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
