Friction, tension, and acceleration combination problem
In summary, the man can give the airplane the greatest acceleration if he pulls the cable at an angle of 9.00 above the horizontal.
jehan4141
91
1. An 85-kg man plans to tow a 109000-kg
airplane along a runway by pulling horizontally on a cable attached
to it. Suppose that he instead attempts the feat by pulling the cable at
an angle of 9.00 above the horizontal. The coefficient of static friction
between his shoes and the runway is 0.77. What is the greatest acceleration
the man can give the airplane? Assume that the airplane is on
wheels that turn without any frictional resistance.
_________________________________________________________________________
MY ATTEMPT AT THE SOLUTION
Forces on Plane
Fn = Normal force
Weight = (mass of plane)(gravity) = 109000(9.8) = 1068200 N
Tx = x-component of tension in rope = Tcos(9)
Ty = y-component of tension in rope = Tsin(9)
Forces on Man
Fn = Normal force
Weight = (mass of man)(gravity) = 85(9.8) = 833 N
Fk = frictional force = (weight)(coefficient of friction) = (833)(0.77) = 641.41 N
Tx = x-component of tension in rope = -Tcos(9)
Ty = y-component of tension in rope = -Tsin(9)
____________________________________________________________________________
net equations for the plane
Fx = Tcos(9) = (Mass of plane)(x-component of acceleration)
Fy = Tsin(9) = (Mass of plane)(y-component of acceleartion)*********
net equations for the man
Fx = Fk - Tcos(9) = (Mass of man)(x-component of acceleration)
Fy = -Tsin(9) = (Mass of man)(y-component of acceleration)*********
From here, i think it is plug and chug to find tension. After I find tension, I can find both the x and y components of acceleration. I can then use Pythagorean theorem to find acceleration from the x and y components.My question is, have I written my net equations correctly? I think something is wrong because when I plug in T to the two starred equations above, I get two different answers for the y-component of acceleration...help? please?
Forces on Plane
Fn = Normal force
Forces on Man
Fn = Normal force
If the plane and man do not leave the ground, is there any acceleration in the y direction?
And don't forget the Normal force in the y direction in your equations.
Note also that Fk is not weight times the friction coefficient, it is ? times the friction coefficient.
Fk is the normal force times the frictional coefficient...but I don't see how that changes anything...? :rolleyes::confused: Hmmm...Does the tension of rope contribute to the normal force? So that the normal force = mg + Tsin9? And thus Fk = 0.77[mg + Tsin9]
Yes, on the man.
Yes, very good. Now continue... (sorry for delayed response, I fell asleep:zzz:
AWESOME! THANK YOU SO MUCH, Phanthomjay...ur my physicss superman hahaha
Related to Friction, tension, and acceleration combination problem
1. What is friction?
Friction is a force that opposes the motion of an object in contact with another surface. It is caused by the roughness of the surfaces and the interlocking of their microscopic particles.
2. How is tension defined?
Tension is a force that is transmitted through a string, cable, or any other type of elongated object. It is always directed along the length of the object and away from its ends.
3. What is the relationship between friction and tension?
Friction and tension are both forces that can affect the motion of an object. Friction acts opposite to the direction of motion, while tension acts in the direction of the string or cable. In some cases, these forces may cancel each other out, resulting in a net force of zero.
4. How do you calculate acceleration in a combination problem?
To calculate acceleration in a combination problem, you need to first identify all the forces acting on the object and their directions. Then, use Newton's Second Law of Motion (F=ma) to calculate the net force. Finally, use the equation a = F/m to find the acceleration.
5. Are there any real-life examples of friction, tension, and acceleration combination problems?
Yes, there are many real-life examples of these combination problems, such as a car driving up a hill (friction and tension acting against gravity), a person pushing a heavy object across the floor (friction and tension acting in opposite directions), and a roller coaster going around a loop (friction and tension working together to maintain the acceleration of the car).
