Frictionless sphere, falling particle
The discussion revolves around determining the angle at which a particle loses contact with a frictionless sphere as it slides down. Initially, participants consider the relationship between the particle's acceleration and the angle of descent, speculating that the critical angle could be 45 or 90 degrees. The conversation shifts to energy conservation principles, noting that as the particle descends, gravitational potential energy converts to kinetic energy, affecting its speed. Ultimately, the correct angle at which the particle loses contact is identified as arccos(2/3), derived through the application of conservation of energy and centripetal force equations. This solution clarifies the mathematical relationship between the forces acting on the particle and its motion on the sphere.
professor
A particle initially sits on top of a large smooth sphere of radius R. The
particle begins to slide down the sphere without friction. At what angle .
does the particle lose contact with the sphere?
g=9.8m/s2 perhaps? (Is this dependent on the acceleration?)
It seems like the angle that the particle loses contact with the sphere is possibly dependent on the acceleration of the particle. If so, I don't know how to mathematically explain this relationship. If the angle is equal to x, sinx will give a tangent vector of a magnitude proportional to the size of the angle, but I don't know if that gets me anywhere.
My second guess is that the particle either loses contact with the sphere at 90 degrees, or 45 degrees. I know that the particle cannot possibly hold on to the sphere without an adhesive property after 90 degrees. I do not know if a particle would be able to stay on the sphere past 45 degrees though.
As the particle slides down it will gain speed according to mgh being converted to kinetic energy. You may recognize that h is a function of θ.
You may also want to recognize that when mv2/R exceeds a certain point that it will lose contact with the sphere.
Thanks, I got it now, the angle is the arccos of 2/3. I just used conservation of energy for the particle, and get mgh+mv^2/r =mgh+mv^2/r, then solved fo V^2 later by equating centripetal force with mgcos(x) so the net force would be 0, where the particle fell off of the sphere.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
