I From a false vacuum to a true vacuum?
Suekdccia
TL;DR Summary
Can vacuum transitions change fundamental particles and fields?
In theory (please correct me if I am wrong in any point), if our vacuum were metastable (i.e. in a "false vacuum" state), it could go through a phase transition into a stable state (a "true vacuum" state). Depending on the properties of the new vacuum, fundamental forces and particles could change or even be replaced by other new ones.
This is only a theoretical mental exercise, but assume that our Standard Model was found to be in a stable vacuum state, or even complete. Also, assume that an enormous energetic event or something similar caused the "true" vacuum to be metastable and decay.
Would this new transitions (from the true vacuum to a false one and the decaying) change the fundamental particles and forces of nature or even replacing them by new other ones?
Demystifier said:
Short answer - yes.
I noticed I messed up with the title so I would like to clarify and confirm:
What I was asking is whether a transition to a false vacuum from an initial true vacuum state (via an energy input from somewhere) and then letting that excited metastable vacuum decay into a lower state (or even return to the previous initial true vacuum ground state) would change the fundamental forces, fields and particles, or even replace them with completely different ones. Is the answer still "yes"?
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
Hello everyone, I am seeking to better understand the conceptual foundations and potential consequences of "Two-Time Physics" (2T-physics), as developed by Itzhak Bars and others. My interest was sparked by a recent paper that attempts to explain anomalous results in particle physics (apparent superluminal propagation of virtual photons) within the framework of 2T-physics: Paper: https://arxiv.org/abs/2408.02696 Key quote from the abstract: *"...the problem... can be solved naturally...
