I From de Broglie's postulates to Shrödinger's equation
  • I
  • Thread starter Thread starter quasar987
    Postulates
quasar987
TL;DR Summary
Trying to make sense of a vague comment by Susskind
So I was watching one of Susskind's lecture on Youtube* and about the 37:00 mark he has this equation relating the frequency of a matter wave to its wavelength:
$$\nu = \frac{h}{2m\lambda^2}.$$
This is arrived at by assuming that matter has a wavelike nature and that the energy and momentum formula for the photon (E=h\nu and p=h/\lambda) still hold true for the matter wave. Then Susskind said that this is essentially just Shr¨ödinger's equation, or at least that Schrödinger was looking for an equation which would result in this relation between \nu and \lambda. But if I set \psi(x,t) = e^{i(x-vt)} and use v=\lambda\nu, then feeding \psi into Shrödinger's equation
$$\frac{1}{2m}\frac{\partial^2}{\partial x^2}\psi = -\frac{i}{h}\frac{\partial}{\partial t}\psi,$$
I find instead
$$\nu = \frac{h}{2m\lambda}.$$
What am I missing??
The Schrödinger equation for a free particle will read (I think you have dropped a factor of ##2\pi##)$$i\hbar \frac{\partial \psi}{\partial t} = -\frac{\hbar^2}{2m} \frac{\partial^2 \psi}{\partial x^2}$$Then if you let ##\psi(x,t) = Ae^{i(kx-\omega t)}##, you have ##\frac{\partial \psi}{\partial t} = - i \omega \psi## and ##\frac{\partial^2 \psi}{\partial x^2} = -k^2 \psi##. If you plug those results in, and use that ##\hbar k = p##, you will notice that$$\hbar \omega = \frac{\hbar^2 k^2}{2m} \implies h\nu = \frac{p^2}{2m}$$Now the velocity of a particle is identified as the group velocity, ##v_g = \frac{\partial \omega}{\partial k}##, which is twice the phase velocity, ##v_p = \frac{\omega}{k}##, i.e. ##v_g = 2v_p = 2\nu \lambda##, which means that$$h\nu = \frac{(mv_g)^2}{2m} = \frac{4\nu^2 \lambda^2 m^2}{2m} = 2\nu^2 \lambda^2 m$$ $$\nu = \frac{h}{2m \lambda^2}$$which is the equation in the video.
Likes quasar987
etotheipi, thanks for your answer! You made me realize that I made two mistakes. The first was to start from \psi(x,t) = e^{i(x-vt)} and not realizing this implies \lambda=2\pi and the other was to forget a factor of 2\pi in the SE. These mistakes "cancel out" in a sense because the computations with the correct factor of 2\pi lead to $$v = \frac{h/2\pi}{2m\lambda}$$ but since 2\pi = \lambda we get the desired form $$\nu = \frac{h}{2m\lambda^2}.$$ Or, in other words, if we (correctly) start from the more general expression\psi(x,t) = \exp\left[i\frac{2\pi}{\lambda}(x-vt)\right] then the SE implies $$v=\frac{2\pi\hbar}{2m \lambda}=\frac{h}{2m \lambda}$$ and finally the fundamental relation v=\lambda\nu gives the desired result.
But you also make the observation that if we trust that p=h/\lambda holds for massive particles as it does for photons, then we get $$v=\frac{p}{2m}=\frac{v_{particle}}{2}.$$ I.e. the velocity of the plane wave "attached" to the particle is half that of the particle itself!
Likes etotheipi
This is the phase velocity. If you take the group velocity, you'll get ##v=p/m##, as expected. That makes some sense, because the velocity of the particle is rather the velocity of the center of the wave packet rather than the phase velocity.
Likes quasar987
This post is a spin-off of the original post that discussed Barandes theory, A new realistic stochastic interpretation of Quantum Mechanics, for any details about the interpretation in general PLEASE look up for an answer there. Now I want this post to focus on this pre-print: J. A. Barandes, "New Prospects for a Causally Local Formulation of Quantum Theory", arXiv 2402.16935 (2024) My main concerns are that Barandes thinks this deflates the anti-classical Bell's theorem. In Barandes...
I understand that the world of interpretations of quantum mechanics is very complex, as experimental data hasn't completely falsified the main deterministic interpretations (such as Everett), vs non-deterministc ones, however, I read in online sources that Objective Collapse theories are being increasingly challenged. Does this mean that deterministic interpretations are more likely to be true? I always understood that the "collapse" or "measurement problem" was how we phrased the fact that...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In her YouTube video Bell’s Theorem Experiments on Entangled Photons, Dr. Fugate shows how polarization-entangled photons violate Bell’s inequality. In this Insight, I will use quantum information theory to explain why such entangled photon-polarization qubits violate the version of Bell’s inequality due to John Clauser, Michael Horne, Abner Shimony, and Richard Holt known as the...
