From fluid energy conservation equation to the continuity equation
The discussion focuses on deriving the continuity equation from the energy conservation equation in fluid dynamics. The user questions the absence of the coefficient ##\gamma## in energy conservation equations found online and explores the implications of substituting energy terms in the equations. They express confusion over whether pressure must remain constant for certain terms to equal zero and struggle to derive the momentum balance equation from the energy balance equation. The conversation highlights the relationship between pressure, density, and energy for ideal gases, emphasizing the need for a proper constitutive equation to facilitate the derivation. Understanding these relationships is crucial for successfully deriving the continuity equation.
happyparticle
Derive the continuity equation from the energy conservation equation
##\frac{De}{Dt} + (\gamma - 1)e \nabla \cdot \vec{u} = - \frac{1}{\rho} (\vec{u} \cdot \nabla)p ##
##\frac{Dp}{Dt} + \gamma p \nabla\cdot \vec{u} = 0##
##\frac{D}{Dt} \frac{p}{\rho^{\gamma}} = 0##
##e = \frac{1}{\gamma -1} \frac{p}{\rho}##
Hey there,
First of all, all energy conservation equations for a fluid I found on google hadn't the ##\gamma## coefficient. What exactly is the difference?
Secondly, by substituting e by ##e = \frac{1}{\gamma -1} \frac{p}{\rho}## in the following equation ##\frac{De}{Dt} + (\gamma - 1)e \nabla \cdot \vec{u} = - \frac{1}{\rho} (\vec{u} \cdot \nabla)p ## I got ##\frac{D}{Dt}(\frac{1}{\gamma -1} \frac{p}{\rho}) + (\gamma - 1)(\frac{1}{\gamma -1} \frac{p}{\rho}) \nabla \cdot \vec{u} = - \frac{1}{\rho} (\vec{u} \cdot \nabla)p ##
=> ## \frac{D}{Dt}(\frac{1}{\gamma -1}) p + p \nabla \cdot \vec{u} = - (\vec{u} \cdot \nabla)p ##
Then, I'm wondering if in this case the pressure is constant to have the right hand side equal to 0?
Anyway, I don't get the expecting result.
That's the energy-balance and momentum-balance equation for adiabatic processes. So you deal with ideal hydrodynamics. The task is to derive the continuity equation
$$\partial_t \rho + \vec{\nabla} \cdot (\rho \vec{u})=0.$$
If I understood
\frac{De}{Dt} + (\gamma - 1)e \nabla \cdot \vec{u} = - \frac{1}{\rho} (\vec{u} \cdot \nabla)p \hspace{10pt} (1)
Is the energy-balance equation
and
\frac{Dp}{Dt} + \gamma p \nabla\cdot \vec{u} = 0 \hspace{10pt} (2)
is the momentum-balanced equation
I'm should be able to get (2) from (1) by replacing ##e## in (1).
vanhees71 said:
No, why?
I have a problem that I have get equation (2) and ##
From equation (1) by replacing e with ##
happyparticle said:
Homework Statement: Derive the continuity equation from the energy conservation equation
Relevant Equations: ##\frac{De}{Dt} + (\gamma - 1)e \nabla \cdot \vec{u} = - \frac{1}{\rho} (\vec{u} \cdot \nabla)p ##
Hey there,
For an ideal gas, you just need a constitutive equation, the speed of sound will do. So from:
\frac{dp}{d\rho}=a^{2}=\frac{\gamma p}{\rho}
You write:
dp=\frac{\gamma p}{\rho}d\rho\Rightarrow\frac{Dp}{Dt}=\frac{\gamma p}{\rho}\frac{D\rho}{Dt}
From here, you can manipulate it however you want.
  • · Replies 32 ·
  • · Replies 26 ·
