From London Equations to Penetration Depth(Integrate Laplacian)
The discussion focuses on integrating London's second equation in superconductivity, specifically the transformation involving the curl of the magnetic field B and the Laplacian operator. The user seeks clarification on how to integrate the equation -del²B = -B/λ² to find B(x) and is confused about the transition to the solution B(x) = B*exp(-x/λ). It is revealed that the general solution to the second-order ordinary differential equation is y = c*exp(x/λ) + c*exp(-x/λ), which satisfies the specified boundary conditions. The user expresses surprise at the simplicity of the solution and acknowledges a lack of familiarity with applying mathematical methods to physics problems. The conversation also touches on the use of LaTeX for formatting mathematical expressions.
calvinjhfeng
(In SI units)
Start with London's 2nd equation in Superconductivity, curl J = 1/(μ*λ²), and Ampere's curl B = μ*j.
Then we curl both side curl curl B = μ* curl J and we do the substitution.
So curl curl B = 0 - del²B which is the laplacian operator.
My question is...how to integrate it?
the equation becomes -del²B = -B/λ²
And I am not sure how to integrate it to solve for B(x). Am I supposed to?
I don't understand how the books jump to B(x) = B*exp(-x / λ)
Please help and thank you very much. Any input is much appreciated too.
what is the solution of the 2nd order ODE:
<br /> y&#039;&#039;(x) - \frac{1}{\lambda^2_L} \, y(x) = 0<br />
that satisfies the following boundary conditions:
<br /> y(x) \rightarrow 0, x \rightarrow \infty<br />
and
<br /> y(0) = y_0<br />
and
OMG it's that easy.
The general solution is just y = c*exp(x/λ) + c*exp(-x/λ),
I never thought of del² works as a second derivative. I thought it's a surface integral in 3 dimensional space or something like that, because gradient and curl are generally three dimensional.
And I have never applied methods to solve differential equations learned from math to physics. Please excuse me as a novice in the field. Thank you very much.
Actually may I ask what program/software did you use to type/print math operators, symbols, and etc ?
latex.
