MHB From the marginal cost to the total cost.
  • Thread starter Thread starter Francobati
    Marginal
The discussion focuses on deriving the total cost (TC) from the marginal cost (MC) function for two companies. The marginal cost is defined as $MC_{i}(q)_{i}=q_{i}+10$, and the goal is to integrate this to find the total cost. By applying integration and the Fundamental Theorem of Calculus, it is established that with no fixed costs, the total cost can be expressed as $TC=\frac{1}{2}q^2+10q$. The parameters used in the integration confirm that the coefficients align with the given marginal cost function. This process illustrates the relationship between marginal and total costs in economic analysis.
Francobati
Hello. Can you help me figure out how to pass, integrating, by the marginal cost: $MC_{i}(q)_{i}=q_{i}+10$ to the total cost: $TC=\frac{1} {2}q_i^2+10q_{i}$?
$i=1,2$, are the two companies. $q_{i}$ is the quantity. What are the calculations?
Mathematics news on Phys.org
Given a marginal cost $C_M$, a fixed cost $C_F$ and a quantity $q$, we are to assume (using the definition of marginal cost) for the total cost $C_T$:
$$\d{C_T}{q}=C_M$$
Now, if we integrate both sides w.r.t $q$, exchange the dummy variables of integration (and use a linear marginal cost function) and using the given boundaries, we obtain:
$$\int_{C_F}^{C_T}\,du=\int_0^q av+b\,dv$$
Applying the FTOC, there results:
$$C_T-C_F=\frac{a}{2}q^2+bq$$
Now, for this problem, it would appear there are no fixed costs ($C_F=0$), and we are given $(a,b)=(1,10)$, hence:
$$C_T=\frac{1}{2}q^2+10q$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
