Frustrating excel problem with COS
  • Thread starter Thread starter tommy060289
    Cos Excel
Excel calculates trigonometric functions like COS using radians by default, which can lead to incorrect results if angles are input in degrees. To resolve this, users can convert degrees to radians using the RADIANS() function, allowing for accurate calculations. For example, using COS(RADIANS(angle_in_degrees)) will yield the correct cosine value for degrees. Additionally, the DEGREES() function can convert radians back to degrees if needed. This method is particularly useful for users handling large datasets, as it avoids the need for manual adjustments to each calculation.
tommy060289
Dear all,
I am currently using excel to work out some values for incident solar radiation but I am running into a rather frustrating problem when I try to do the following:
=COS(9.863)
my calculator tells me correctly this is 0.985.
however, when I put this in excel it decides it actually equals 0.905, which is obviously wrong.
I've gathered this is an issue with excel giving the answer in Rads rather than degrees but I can not figure out how you force excel to output the correct answer (in degrees) and since I have thousands of calculations it isn't feasible for me to alter every one manually.
Cheers,
Tom
Computer science news on Phys.org
No worries, figured I can get it to change by adding:
*(Pi()/180) on the end
You can also use the RADIANS() function: COS(RADIANS(angle_in_degrees)).
And if you ever need to go the other way, there's a DEGREES() function: DEGREES(ACOS(x)).
Just to clarify, hopefully you realize the output result of =cos(9.863) is not in radians, it is the input number 9.863 that Excel assumes is in radians.
I didn't know that, thanks for the tip!
Well, the date has now passed, and Windows 10 is no longer supported. Hopefully, the readers of this forum have done one of the many ways this issue can be handled. If not, do a YouTube search and a smorgasbord of solutions will be returned. What I want to mention is that I chose to use a debloated Windows from a debloater. There are many available options, e.g., Chris Titus Utilities (I used a product called Velotic, which also features AI to prevent your computer from overheating etc...
After playing around a bit with making star maps, I found another video which introduced me to another trick that can be done using geometry nodes. This one involves fluids. For background, Blender has a fluid physics simulator, which, as the name suggests simulates the behavior of fluids. What this person did was to use geometry nodes to convert the fluid into a point cloud. Then he added a turbulence force field to "stir it around". He was then able to extract the velocity information...
I have been idly browsing what Apple have to offer with their new iPhone17. There is mention of 'Vapour cooling' to deal with the heat generated. Would that be the same sort of idea that was used in 'Heat Pipes' where water evaporated at the processor end and liquid water was returned from the cool end and back along a wick. At the extreme high power end, Vapour Phase Cooling has been used in multi-kW RF transmitters where (pure) water was pumped to the Anode / or alternative Collector and...
