MHB F's question at Yahoo Answers involving absolute extrema
  • Thread starter Thread starter MarkFL
    Absolute Extrema
The absolute extrema of the function f(x) = x^3 - 2x^2 - 4x + 8 on the interval [-1, 3] are determined by evaluating critical points and endpoints. The critical values found are x = -2/3 and x = 2, with corresponding function values of approximately 9.48 and 0, respectively. The endpoint evaluations yield f(-1) = 9 and f(3) = 5. The absolute minimum occurs at (2, 0) and the absolute maximum at (-2/3, 256/27). This analysis provides a clear understanding of the function's behavior within the specified interval.
MarkFL
MHB
Here is the question:
Math Question - Calculus!?
Find the absolute maxima and minima for f(x) on the interval [a, b].
f(x) = x3 − 2x2 − 4x + 8, [−1, 3]
absolute maximum
(x, y) =
absolute minimum
(x, y) =
Here is a link to the question:
Math Question - Calculus!? - Yahoo! Answers
I have posted a link there so the OP can find my response.
Mathematics news on Phys.org
Hello F,
The absolute extrema of a function on some interval can occur either at the critical values, or at the end-points of the interval.
To determine the critical values of the given function:
[math]f(x)=x^3−2x^2−4x+8[/math]
we equate the first derivative to zero, and solve for $x$:
[math]f'(x)=3x^2-4x-4=(3x+2)(x-2)=0[/math]
Hence, the critical values are:
[math]x=-\frac{2}{3},\,2[/math]
The critical points are then:
[math]\left(-\frac{2}{3},f\left(-\frac{2}{3} \right) \right)=\left(-\frac{2}{3},\frac{256}{27} \right)[/math]
[math](2,f(2))=(2,0)[/math]
The end-point values are:
[math](-1,f(-1))=(-1,9)[/math]
[math](3,f(3))=(3,5)[/math]
Since [math]0<5<9<\frac{256}{27}[/math] we may state that:
Absolute minimum occurs at $(2,0)$.
Absolute maximum occurs at [math]\left(-\frac{2}{3},\frac{256}{27} \right)[/math]
To F and any other guests viewing this topic, I invite and encourage you to post other absolute extrema questions here in our http://www.mathhelpboards.com/f10/ forum.
Best Regards,
Mark.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
