Full implications of bell's inequality
  • Thread starter marky3
  • Tags
    Inequality
In summary, the violation of Bell's inequality in experiments consistently aligns with the predictions of quantum theory, which denies both locality and hidden variables. However, this does not necessarily imply that there is both non-locality and no hidden variables, as it depends on the specific definitions of these terms.
marky3
The violation of Bell's inequality is often said to imply that either there exists non-locality or there are no hidden variables. In actual experiments it is consistenly found that the inequality is violated by precisely the amount predicted by quantum theory. But quantum theory denies both locality and hidden variables. Therefore aren't we to conclude that the violation of Bell's inequality implies that there is both non-locality and no hidden variables?
Why do you think it denies them? It doesn't include any hidden variables, for example, but that's not the same as "denying" them. Quantum theory is just a recipe for making predictions about the probabilities of different measurable events, with no built-in interpretation of where these probabilities come from or what they "mean", so there's no reason in principle it couldn't turn out to be an approximation to some more detailed theory. And we know that conventional nonrelativistic QM makes exactly the same predictions as Bohmian mechanics, which does include hidden variables, assigning particles a well-defined position at all times...nothing about the QM formalism rules out the possibility that some other model like Bohmian mechanics could describe the underlying "reality", provided the model makes the same probabilistic predictions as ordinary QM.
Could be. I would say that it is highly dependent on your precise definition of non-locality and "no hidden variables". It is generally agreed that with common definitions of each, the answer to your question is NO. But with different definitions - which could also be considered reasonable in some ways - the answer might be YES.
FAQ: Full implications of bell's inequality
What is Bell's inequality?
Bell's inequality is a mathematical expression that is used to test whether local hidden variable theories, which propose that particles have predetermined properties that are not affected by measurement, can accurately describe the behavior of entangled particles. It is used to determine whether quantum mechanics, which states that particles can be in multiple states at once and their properties are influenced by measurement, is a more accurate description of reality.
How is Bell's inequality tested?
Bell's inequality is tested through experiments that involve entangled particles. These particles are separated and their properties are measured. If the results of the measurements violate Bell's inequality, it supports the theory of quantum mechanics.
What are the implications of Bell's inequality?
The implications of Bell's inequality are that it provides evidence for the validity of quantum mechanics and challenges the idea of local hidden variable theories. It also opens up the possibility for applications in quantum computing and communication.
What are the limitations of Bell's inequality?
Bell's inequality is limited by the fact that it only tests for the existence of local hidden variables and does not rule out the possibility of non-local hidden variables. It also assumes that the measurements are done simultaneously, which may not always be the case in real-life experiments.
What are the practical applications of Bell's inequality?
The practical applications of Bell's inequality include quantum cryptography, which uses the entanglement of particles to ensure secure communication, and quantum computing, which utilizes the principles of quantum mechanics to perform complex calculations at a much faster rate compared to classical computers.
