B Fully submerged block in a pool of water
The discussion centers on the forces acting on a submerged block of iron, specifically addressing the confusion between buoyancy and hydrostatic pressure. It clarifies that buoyancy and hydrostatic pressure are essentially the same, and using both in calculations leads to double counting. The upward force can be determined by the pressure difference between the top and bottom surfaces of the object, which equals the weight of the displaced water. Additionally, the ability of water to flow under the block affects whether buoyancy applies; if water cannot flow underneath, buoyancy is not relevant. The conversation emphasizes understanding the conditions under which these forces operate to avoid miscalculations.
adjurovich
Let’s say we let a block of iron sink into the water and it reaches the bottom.
Would the force pushing on body towards the bottom be: ##F_{downwards}=mg+F_P##
where ##F_P## is the force caused by hydrostatic + atmospheric pressure.
The force acting upwards should be then: ##F_{upwards}=F_B+N##
Where ##F_B## is buoyancy and ##N## is the normal force (reaction force exerted by the bottom of pool or anything else that’s filled with water).
So these two balance each other: ##F_{upwards}=F_{downwards}##
We are assuming that we are dealing with non-viscous ideal fluid. And the block is in full contact with the bottom of pool.
No. This is not a good list of forces.
Buoyancy and hydrostatic pressure are the same thing. You can use one. Or you can use the other. You should not use them both at the same time.
For example, consider a submarine in the water. You can compute the upward force from water pressure on the bottom surface of the submarine. You can compute the downward force from water pressure on the top surface of the submarine. You can subtract the two. The net of those two forces will exactly match the weight of the water that the submarine displaces. [The appropriate integral of] hydrostatic pressure difference is buoyancy.
If you add the force of buoyancy to the force from hydrostatic pressure difference, you will be counting the same forces twice!
But there is another problem lurking here. What is the texture of the bottom of the iron block?
If free flowing water can make its way under the block so that hydrostatic pressure applies on all sides then buoyancy is applicable. One can summarize hydrostatic pressure as buoyancy. One might assume that some negligible surface area (bumps on the bottom) is subject to non-negligible total normal contact force.
However, if free flowing water cannot make its way under the block then buoyancy is not applicable. [Think of a suction cup]. One can consider hydrostatic pressure on the top of the block only and plain old vanilla total contact force on the bottom. You have clarified that this is the actual situation.
Likes russ_watters, Lnewqban and adjurovich
Thanks for help, I get it now!
It's all a matter of the timescale involved and whether or not water can flow in underneath. This is a fun video which 'we' have all seen and it makes the point with air, rather than water.
PS Have you ever stepped out of a wellie boot when you were walking in deep mud? Same thing.
Likes Vanadium 50
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
