Fun Puzzles: Test Your Math Skills!
In summary: Oops! I was thinking $\displaystyle\prod_{0\leq k\leq n}(1+x^{2^k})=1+\sum_{1\leq m\leq2^{n+1}-1}x^m$ which is clearly wrong: $x^8$ isn't included in the sum. I think I had a pretty good explanation of the effect of multiplying the geometric series when I first saw this problem, but I forgot it. The explanation I gave was a poor replacement.Apparently it was a good replacement -__- If you consider the geometric series as a polynomial, then the product of two geometric series is the sum of all the different products of its terms. Well, the terms
sbhatnagar
87
Fun Problems! Evaluate the following:
1. \( \displaystyle \sum_{n=1}^{\infty}\frac{\left( 1+\dfrac{1}{1!}+\dfrac{1}{2!}+\cdots +\dfrac{1}{(n-1)!} \right)}{2^{n-1}}\)
2. \( \displaystyle \sum_{n=1}^{\infty}\frac{1+2+2^2+\cdots+2^{n-1}}{n!}\)
3. \( \displaystyle \sum_{n=1}^{\infty}\frac{(1+3^n)\ln^n(3)}{n!}\)
4. \( \displaystyle \sum_{n=1}^{\infty}\dfrac{\displaystyle x^{2^{n-1}}}{\displaystyle 1-x^{2^n}} \)
5.\( \displaystyle \sum_{n=0}^{\infty}\dfrac{\displaystyle 2^n x^{x^{2^n}-1}}{\displaystyle 1+x^{2^n}} \)
Mathematics news on Phys.org
Write first series as $\displaystyle\sum\limits_{n=1}^{\infty }{\sum\limits_{j=1}^{n}{\frac{1}{{{2}^{n-1}}(j-1)!}}}=\sum\limits_{j=1}^{\infty }{\sum\limits_{n=j}^{\infty }{\frac{1}{{{2}^{n-1}}(j-1)!}}},$ we can reverse order of summation because of the positivity of the terms of the double series, so now things are straighforward.
You can do similar stuff on second series. Third series is easy by using the expansion of $e^x.$
$\displaystyle \sum_{n \ge 1}~\sum_{0 \le k \le n-1}\frac{2^k}{n!} = \sum_{n \ge 1}\frac{2^n-1}{n!} = \sum_{n \ge 0}\frac{2^n}{n!}-\sum_{n \ge 0}\frac{1}{n!} = e(e-1).$
Solution to Problem 1:
Let \( \displaystyle S=\sum_{n=1}^{\infty}\frac{\left( 1+\dfrac{1}{1!}+\dfrac{1}{2!}+\cdots +\dfrac{1}{(n-1)!} \right)}{2^{n-1}}\).
Let \( \displaystyle t_{n}=\frac{\left( 1+\dfrac{1}{1!}+\dfrac{1}{2!}+\cdots +\dfrac{1}{(n-1)!} \right)}{2^{n-1}}\)
\( \displaystyle \begin{align*} t_{n+1} &= \frac{\left( 1+\dfrac{1}{1!}+\dfrac{1}{2!}+\cdots +\dfrac{1}{(n-1)!}+\dfrac{1}{(n)!} \right)}{2^{n}} \\ t_{n+1} &= \frac{1}{2}\frac{\left( 1+\dfrac{1}{1!}+\dfrac{1}{2!}+\cdots +\dfrac{1}{(n-1)!}+\dfrac{1}{(n)!} \right)}{2^{n-1}} \\ t_{n+1} &= \frac{1}{2}t_n +\frac{1}{2^n n!} \\ \sum_{n=0}^{\infty}t_{n+1} &=\frac{1}{2}\sum_{n=0}^{\infty}t_n + \sum_{n=0}^{\infty} \frac{1}{2^n n!} \\ S & =\frac{S}{2}+\sqrt{e} \\ S &= \boxed{2\sqrt{e}}\end{align*}\)
Try solving the last two problems. They are very tricky. :)
My approach for first series is pretty short, the next step is $\displaystyle\sum\limits_{j = 1}^\infty {\frac{1}{{{2^{j - 1}}(j - 1)!}}\sum\limits_{n = 0}^\infty {\frac{1}{{{2^n}}}} } ,$ then combining the value of both series the result equals $2\sqrt e.$
Don't post solutions yet. I'm working on them.
(Nod)
Are you sure the last one is correct, though?
---------- Post added at 01:45 AM ---------- Previous post was at 12:00 AM ----------
$\displaystyle \begin{aligned} 3. ~f(x) & = \sum_{n \ge 1}\frac{(1+3^n)x^n}{n!} = \sum_{n \ge 1}\frac{x^n}{n!}+\sum_{n \ge 1}\frac{3^nx^n}{n!} \\& = e^{3x}+e^x-2 \Rightarrow f(\ln{3}) = 28.\end{aligned}$
$\displaystyle \begin{aligned} 5. ~ S & = \sum_{n \ge 0}\frac{2^nx^{2^n-1}}{1+x^{2^n}} = \sum_{n \ge 0}\frac{(1+x^{2^n})'}{1+x^{2^n}} = \bigg[\sum_{n \ge 0}\ln\left(1+x^{2^n}\right)\bigg]' \\& = \bigg[\ln\bigg(\prod_{n \ge 0} (1+x^{2^n})\bigg)\bigg]' = \bigg[\ln\bigg(\frac{1}{1-x}\bigg)\bigg]' =\boxed{\dfrac{1}{1-x}}. \end{aligned}$
Sherlock said:
Don't post solutions yet. I'm working on them. (Nod)
Yes, you are correct. :)
I wasn't aware that $\displaystyle \prod_{n=0}^{\infty} \left(1+x^{2^{n}} \right) = \sum_{n=0}^{\infty} x^{n} $. But from just writing out terms it appears to be true.
We have $\displaystyle \prod_{0 \le k \le n}\left(1-x^{2^{k}}\right) = \frac{\left(1-x\right)}{\left(1-x^{2^{n+1}}\right)}\prod_{1 \le k \le n+1}\left(1-x^{2^{k}}\right) = \frac{\left(1-x\right) }{\left(1-x^{2^{n+1}}\right)}\prod_{0 \le k \le n}\left(1-x^{2^{k+1}}\right). $
But $\displaystyle \left(1-x^{2^{k+1}}\right) = \left(1-x^{2^{k}}\right)\left(1+x^{2^{k}}\right)$, thus $\displaystyle \prod_{0 \le k \le n}\left(1-x^{2^{k+1}}\right) =\prod_{0 \le k \le n}\left(1-x^{2^{k}}\right)\prod_{0 \le k \le n}\left(1+x^{2^{k}}\right). $
Thus $\displaystyle \frac{\left(1-x\right)}{\left(1-x^{2^{n}}\right)}\prod_{0 \le k \le n}\left(1+x^{2^{k}}\right) = \frac{\prod_{0 \le k \le n}\left(1-x^{2^{k}}\right)}{\prod_{0 \le k \le n}\left(1-x^{2^{k}}\right)} = 1 \implies \prod_{0 \le k \le n}\left(1+x^{2^{k}}\right) = \frac{1-x^{2^{n+1}}}{1-x}. $
The difference of two squares can do wonders! We get our case when $n \to \infty$ of course.
Let \( \displaystyle S=\sum_{n=1}^{n}\dfrac{\displaystyle x^{2^{n-1}}}{\displaystyle 1-x^{2^n}} \)
\( \displaystyle S=\sum_{n=1}^{\infty}\dfrac{\displaystyle x^{2^{n-1}}}{\displaystyle 1-x^{2^n}} =\sum_{n=1}^{\infty}\frac{x^{2^{n-1}}+1-1}{(1-x^{2^{n-1}})(1+x^{2^{n-1}})} = \sum_{n=1}^{\infty} \frac{1}{(1-x^{2^{n-1}})}-\frac{1}{(1-x^{2^{n-1}})(1+x^{2^{n-1}})} = \sum_{n=1}^{\infty}\frac{1}{(1-x^{2^{n-1}})}-\frac{1}{(1-x^{2^{n}})}\)
\( \displaystyle S=\frac{1}{1-x}-\frac{1}{1-x^2}+\frac{1}{1-x^2}-\frac{1}{1-x^4}+\cdots= \boxed{\dfrac{1}{1-x}}\)
(Music)
I think there's a simpler reason. When multiplying out, we find that $\displaystyle\prod_{0\leq k\leq n}(1+x^{2^k})$ is the sum of terms of the form $x^m$ (except for $1$), where $m$ is a sum of powers of two. Then we may notice that any $1\leq m\leq2^{n+1}-1$ is obtained exactly once because any number can be written uniquely in base-2 representation.
For example, take $n=3$: $(1+x^{2^0})(1+x^{2^1})(1+x^{2^2})(1+x^{2^3})=1+x^{2^0}+x^{2^1}+x^{2^0+2^1}+x^{2^2}+x^{2^0+2^2}+x^{2^1+2^2}+x^{2^0+2^2+2^2}=1+x+x^2+x^3+x^4+x^5+x^6+x^7$
Therefore, $\displaystyle\prod_{0\leq k\leq n}(1+x^{2^k})=1+\sum_{1\leq m\leq 2^{n+1}-1}x^m$
መለሰ
FAQ: Fun Puzzles: Test Your Math Skills!
What is "Fun Puzzles: Test Your Math Skills!"?
"Fun Puzzles: Test Your Math Skills!" is a collection of entertaining and challenging puzzles designed to test and improve your math skills. It includes various types of puzzles such as number sequences, logic puzzles, and word problems.
Who is this book suitable for?
This book is suitable for anyone who enjoys solving puzzles and wants to enhance their math skills. It is appropriate for all ages and levels, from beginners to advanced mathematicians.
How can this book help improve my math skills?
By solving the puzzles in this book, you will be practicing and honing various math skills such as problem-solving, critical thinking, and mathematical reasoning. It will also help you become more comfortable and confident with numbers and mathematical concepts.
Are the puzzles in this book challenging?
Yes, the puzzles in this book are designed to be challenging and engaging. They range from easy to difficult, so there is something for everyone. They will push you to think outside the box and improve your problem-solving abilities.
Can I use this book for educational purposes?
Yes, this book is a great resource for educators and parents who want to supplement math education with fun and stimulating activities. It can be used in classrooms, homeschooling, or as a fun way to practice math skills at home.
