I Fundamental theorem of arithmetic from Jordan-Hölder theorem
eoghan
TL;DR Summary
I propose a proof of the fundamental theorem of arithmetic based on the Jordan-Hölder theorem. I would like to know if the proof makes sense.
I was intrigued by a comment in Brilliant.org:
In fact, it is not hard to show that the fundamental theorem of arithmetic follows from Jordan–Hölder
Besides the proof provided by Brilliant, I also found a couple of other websites. But none of these proofs were entirely clear to me. So I tried to come up with my own proof. Since I am not a group theorist, I wanted to ask if the proof makes sense, or if there are some mistakes.
Let ##n## be a positive integer. Let's consider ##\mathbb{Z}_n##, I know that
the quotient ##\mathbb{Z}_n/\mathbb{Z}_d## is defined and is simple if and only if ##n/d=p## with ##p## prime.
This allows us to create a composition series for ##\mathbb{Z}_n##. Let's take ##p_1## be a prime number dividing ##n## and consider ##\mathbb{Z}_\frac{n}{p_1}##. Because of what we said, ##\mathbb{Z}_n/\mathbb{Z}_\frac{n}{p1}## is simple. Let's now take another prime ##p_2## that divides ##\frac{n}{p_1}## and consider ##\mathbb{Z}_\frac{n}{p_1p_2}##. Then ##\mathbb{Z}_\frac{n}{p_1}/\mathbb{Z}_\frac{n}{p_1p_2}=p_2## and is therefore simple. We can then build
\mathbb{Z}_n \triangleright \mathbb{Z}_\frac{n}{p_1} \triangleright \mathbb{Z}_\frac{n}{p_1p_2}
We can continue this process until ##\frac{n}{p_1...p_k}## is prime. Then we take as next subset ##\mathbb{Z}_1=\{0\}## and we have ##\mathbb{Z}_\frac{n}{p_1...p_k}/\mathbb{Z}_1=\frac{n}{p_1...p_k}## prime. So we found the composition series
\mathbb{Z}_n \triangleright \mathbb{Z}_\frac{n}{p_1} \triangleright \mathbb{Z}_\frac{n}{p_1p_2}\triangleright...\triangleright \mathbb{Z}_1 = \{0\}
But since ##n=p_1...p_k##, I can rewrite the composition series as
\{0\} \triangleleft \mathbb{Z}_{p_1} \triangleleft \mathbb{Z}_{p_1p_2}\triangleleft...\triangleleft \mathbb{Z}_{p_1...p_k}=\mathbb{Z}_n
I could have also chosen another decomposition of ##n## to obtain the series
\{0\} \triangleleft \mathbb{Z}_{q_1} \triangleleft \mathbb{Z}_{q_1q_2}\triangleleft...\triangleleft \mathbb{Z}_{q1...q_l}=\mathbb{Z}_n
By the Jordan-Hölder theorem, the two series must be equivalent, i.e. the set
##\{p_1,...,p_k\}## must be isomorphic to the set ##\{q_1,...,q_l\}## and it also proves that ##n## can be decomposed into prime factors. Therefore, this proves the fundamental theorem of arithmetic.
Do you think this proof is correct, or am I overlooking something?
Looks ok.
I have some minor remarks:
1.) ##\mathbb{Z}_n / \mathbb{Z}_d## is only defined if ##d\,|\,n,## not always.
2.) Where do you take the existence of ##p_1## from?
3.) Why does a composition series exist? Not that you have hidden a circular reasoning here!
4.) ##\{p_1,\ldots,p_k\} = \{q_1,\ldots,q_l\}## (up to ##\pm 1##) not isomorphic.
Thank you for checking.
1. Correct, ##d## must divide ##n##. I need to specify this better.
2. Yes, this needs an explanation. I was simply supposing that if ##n## is not prime, then there exists a prime number that divides ##n##. But this is a consequence of the FTOA, that I am trying to prove here. What I am doing here is just proving the uniqueness of the factorisation. I need to think if there is a group theory tool to argue that ##p_1## exists.
3. If we assume that a non prime number is divisible by a prime number, see point above, then the composition series exists because during the proof I build it (i.e, take one prime number ##p_1## that divides ##n## and consider ##\mathbb{Z}_{n/p_1}\triangleleft \mathbb{Z}_n## and so on).
4. I am not sure I understand what you mean here. I guess with (up to ##\pm 1##) you mean that the sets do not contain ##\pm 1##, because ##1## is not prime. But why are they not isomorphic?
You could take an element of lowest highest order. That also proves ##p_1\,|\,n## (Lagrange). Since primality and irreducibility are exchangeable, this should prove primality.
Yes, seems convincing. A note that the group orders decline with each step without repetitions would help to guarantee that it comes to an end. ##(\mathbb{Z},+) ## has no composition series.
I mean that every statement about prime numbers is always up to units, and the units in ##\mathbb{Z}## are ##\pm 1.## ##-5## is as prime as ##5## is. Mention that we only consider positive numbers and done. But I mainly meant that sets are equal or not, containing each other or not. They are not isomorphic since there is no "morph" on sets.
It makes sense!
Thank you for checking it out and for the hints :)
eoghan said:
It makes sense!
I had to correct myself: take an element of highest order, not lowest for irreducibility. High order means low prime, I confused them.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
