Fundamental thermodynamics relation
In summary, the equation U=U(S,V,N,...) is commonly used to summarize the work that a system does. The three historically most important work and heat terms are summed up into this equation. Other terms can be introduced as needed in other fields.
davidge
554
I was looking at the fundamental equation ##dU = Tds - Pdv + \sum_i \ \mu_i \ dN_i## and I was thinking of how many different ways one has for deriving it.
I know I have to look through a book on Thermodynamics. I actually have done that some time ago and I will do that again. But the following seems to me not to violate any principle of physics. So I just like to know whether it is valid.
So one way of thinking about the fundamental equation above seems like
Suppose we increase the energy of a system by a tiny amount. This corresponds (in average) to an increase of the kinetic energy of a typical molecule of the system. As the system expands after we added the tiny amount of energy to it, that increment on the kinetic energy of the particle is lost by the work the particle has done. The last term in the equation could the regarded as due chemical interactions of molecule-to-molecule, and the plus sign indicates that the potential energy associated with the interaction becomes less negative as molecules moves a little bit apart from each other.
Science news on Phys.org
I think your intuitive idea is OK. The variation in the internal energy could arise due to different types of works and/or heat addition. You indicated 3 of them (heat, mechanical work, and chemical work). But there many others and each work will extend dU by another term. For example elastic work (σdε), polarization work (EdD), ...
For chemical work, you can simply think of it as the energy needed to add one more particle to a system that has already N particle. Chemical reactions, as you mentioned, are complex and involve variations in many types of work and/or heat.
Likes davidge
Thanks, @Useful nucleus. So is it correct to add up all the other contributions into the fundamental equation? If so, why is it usually presented in the form I wrote above (i.e. the terms not included)?
Yes, all kinds of possible work processes can be summed up into the equation you wrote above. Texts usually reserve the term fundamental equation to U=U(S,V,N,...) or S=S(U,V,N,...) instead of their first differentials like the one you wrote above. Authors claim that for the purposing of studying thermodynamics, let's just focus on the three historically most important work and heat terms. In other fields where thermodynamics is applied the other terms can be introduced as needed. For example when you study elasticity, one certainly meets σdε. A favorite of mine is Herbert Callen's introduction to thermodynamics where he warns the reader about these other terms and from time to time gives problems on magnetic work.
I also found the following IUPAC technical report to be very useful in discussing many of these work terms. See table 1:
https://pdfs.semanticscholar.org/4377/766430bebdf5b1b18b88f61493d9ce47d466.pdf
Likes davidge
Related to Fundamental thermodynamics relation
What is the fundamental thermodynamics relation?
The fundamental thermodynamics relation is a fundamental equation that describes the relationship between the thermodynamic quantities of a system, including energy, temperature, and entropy. It is a fundamental concept in thermodynamics and is used to analyze and understand the behavior of physical systems.
What are the variables involved in the fundamental thermodynamics relation?
The variables involved in the fundamental thermodynamics relation are energy, temperature, and entropy. These quantities are interrelated and can be expressed mathematically using the fundamental thermodynamics relation.
How is the fundamental thermodynamics relation derived?
The fundamental thermodynamics relation is derived from the laws of thermodynamics, specifically the first and second laws. It is a mathematical representation of these laws and serves as a basis for understanding the behavior of thermodynamic systems.
What is the significance of the fundamental thermodynamics relation?
The fundamental thermodynamics relation is significant because it allows us to understand and analyze the behavior of physical systems in terms of energy, temperature, and entropy. It also serves as the basis for more complex thermodynamic equations and models.
How is the fundamental thermodynamics relation used in practical applications?
The fundamental thermodynamics relation is used in various fields, including engineering, chemistry, and physics, to analyze and design systems and processes. It is also used in the development of new technologies and to improve the efficiency of existing systems.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
